What causes error cc in tally t5040
When you power it on it displays cc_ error.
2 Suggested Answers
techworm
  • 56 Answers
SOURCE: Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Posted on Mar 21, 2012
How do I get Tally T5040 passbook Printer driver?
Check the manufacturers website (dascom.com):
http://www.dascomamericas.com/Support/Default.aspx?type_id=3&info_id=5&itemid=23&name=T5040&act=4
Jan 07, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
How do i check warranty of Tally T5040 printer?
you can call here (800) 426-4813, Option 3 or email them with the product info @ techsupport@tallygenicom.com . the will probably ask you for the model # and part # and on the phone will help you find them.
Apr 04, 2014 | Computers & Internet
Mar 21, 2012 | Office Equipment & Supplies
Error code=403, system error code=10060. This is the message tally client displays. Tally server running successfully. Pls help. thanks
Sep 14, 2010 | Computers & Internet
Describe your Tally Matrix T2280 Prion power up
Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
· Start with the printer powered OFF and at normal room temperature
· Hold down the ONLINE and SETUP button and power the printer back on
· Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
· Press the button under ‘TEMP CAL’ (button 3)
· Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
· Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
Jul 09, 2009 | Tally Matrix T2280 Printer
Tally data split for new financial year regarding..
I am trying to split tally data,but it displays error mesg "Exiting Tally !!"
"Internal Error"
"Software Exception c0000005(Memory Access Violation)"
Jaya
Mar 28, 2009 | Computers & Internet
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Apr 09, 2008 | Tally Matrix T2280 Printer
Blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the tallygenicom.com site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
Jul 27, 2007 | Tally Line Matrix T6100 Printer
21 people viewed this question
k24674
jasbo
jasbo
