Program is not changing and on display key sign is there. how to remove key sign and to change program to start washing
SOURCE: "Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
SOURCE: when I start a program, It displays
try this - press start, press start again. Now press the on/off button and the start button at the same time and hold them down for 5-10 seconds until the display shows d-end or d-off.
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
