Lg wd 80260t
PE
2 Suggested Answers
  • 207 Answers
SOURCE: I have a LG WD-1018C
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Posted on Mar 09, 2011
When machine is starting PE is displayed lg tromm wd 82260np
water pressure gauge is not faulty or it tube channel blooked.....check on the smalltube ,,detached it from the valve situated at the top,,,blow the tube through to see if there is air passage, if good maybe the gauge,,,,,,,,,alway white or light brown in color with three wire clip
Jan 19, 2015 | LG Washing Machines
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
What does "PE" error message
LG's 'PE' refers to '(water) Pressure Error'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 18, 2011 | LG WD-16115FD Front Load Washer
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
Mar 09, 2011 | LG Washing Machines
Lg front loader washer error code -PE
PE error code means there is an pressure sensor error in your machine .
You need to check pressure it will be giving incorrect indication .
Pressure switch is faulty you need to change it .
Procedure for changing it is :
  • Power off the machine remove backcover and top cover.
  • The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached.
  • It generallysits just under the top cover.
Hope this helps.
Thanks for using Fixya.
Shane
Jan 20, 2010 | LG Washing Machines
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
