Hc error code multi split inverter
Gree model gwhd(28)nk3a0
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Hi my LG healthplus inverter
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Posted on Jan 20, 2011
  • 3 Answers
SOURCE: My new gree air conditioner split system has an E1 error
http://www.aliexpress.com/item/2013-Residential-Air-Conditioner-Commercial-Air-Conditioner-Spare-Part-GREE-Air-Conditioner-Remote-Control-Y512/893088745.html
Posted on Jul 05, 2013
New install Gree 3 head 24k btu ductless mini split. Ran for 3 weeks, then got 3 red flashes on outside unit board. Compressor does not kick on anymore. Fan units inside just blow room temp air.
It's low on refrigerant. Chances are it's on one of the flare fittings where the copper connects to the unit. You should have a one year labor warranty from the installer, should not cost you anything...3 WEEKS???
Apr 15, 2017 | Heating & Cooling
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
Gree air conditioner error codes HC
I have also use GRE ac inverter but today my ac on running sundunly show (HC )Main screen
Plz information this system
HC maens what's problem
Aug 19, 2013 | Heating & Cooling
I have an LG inverter split system which is coming up the error C5. What can I do to fix this problem?
Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Jan 06, 2011 | LG Heating & Cooling
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My greewall mounted has a e1 prblem.how van ifixor what is the problem
Feb 09, 2010 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
