Question about Lexmark X Office Equipment & Supplies
My lexmark x125 won`t print with new ink - X Lexmark Office Equipment & Supplies
    New Friend:
  • 3 Answers
Malfunction code c3451 bizhub 350/250/200 problem solve
Posted on Jul 20, 2013
SOURCE: Lexmark P6250 black ink cartridge won t print
Write to Lexmark - you won't get any joy, but their reply might be interesting. I suspect that Lexmark builds a chip into their cartridges preventing it being refilled. When replying to me they did not admit this, but did not deny it, simply stating that their cartridges were designed for single use only. When I said that, apart from the cost, I wanted to minimise my impact on the environment by refilling cartridges, they pointed out their proud association with Planet Ark. I suspect that Planet Ark is happy to be an apologist for corporate vandals, and I seriously question their 'green' credentials. Order your next cartridges from Europe where the printer companies are not allowed to chip their products.
Posted on Sep 02, 2007
SOURCE: Lexmark X125 installtion without the CD
I need to install my printer and I don't have my cd it is a Lexmark X125
Posted on Sep 12, 2008
vegakitten20
  • 685 Answers
SOURCE: refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Posted on Jan 08, 2009
  • 408 Answers
SOURCE: Lexmark x125 all in one won't print from memory.
Did you go into your printer properties and select new cartidge installed?  If this doesn't work, take the cartridges out and clean the contacts on the side and in the carrier with a qtip and rubbing alcohol.  Give it a few minutes to dry and reinstall the cartridges.
Posted on Mar 11, 2009
Roop1980
  • 228 Answers
SOURCE: lexmark x125
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Posted on Apr 10, 2009
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Change color ink message won't clear from machine
look for the all in one icon, then choose the change cartridges, say to pc that are news cartridges, that will raise de ink level.
Jul 24, 2009 | Lexmark X125 All-In-One InkJet Printer
Installing ink cartridge in Lexmark X125
The front panel is hinged at the bottom so grab the top and pull towards you.  Under that is a protective cover, the one with the 2 paper guides.  towards the bottom of that there is a hole in the middle.  Put your thumb in it and lift the cover up.  Your carrier for the cartridge is under that.  Please Rate!
http://www.lexmark.com/publications/eng/x125/index.html
That link will give you the manual..just in case you need it.
Mar 11, 2009 | Lexmark X125 All-In-One InkJet Printer
LEXMARK 125 PRINTS BLANK PAGES
have you when into printer properties and done maintence such as "clean cartriges".  If so, it may be possible the ink cartidges are bad.
Mar 01, 2009 | Lexmark X125 All-In-One InkJet Printer
Jan 10, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark X125 not printing at all.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark X125 All-In-One InkJet Printer
Used Lexmark X125 Printer
change your printer cable athen probelm remains uninstall driver install again.
Oct 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmrk x125 all-in-one printer
As you do not have the disk with you, rather than finding the disk you can get all the software, drivers. manuals( user guide ) on the website. It is available free for you to download. I have mentioned the link below
http://support.lexmark.com/static/229-1-0-346.html
Hope you find all the info you are looking for on this link.
Will wait for the ratings.
Thanks
Sammy
Dec 05, 2007 | Lexmark X125 All-In-One InkJet Printer
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
