Question about True T-49 Side by Side Refrigerator Commercial
Evaporator fans not working - True T-49 Side by Side Refrigerator Commercial
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
1st water dispenser not working now EF code
EF code on a Frigidaire refrigerator means Evaporator Fan problem. The motherboard on the FGHC2345LF can be sensing a problem with your evaporator fan. The fan could be failing so I advise that you keep an eye on the evaporator fan. All cooling will stop if this fan fails. I believe you are having two unrelated issues. The=> 241734302 Water Inlet Valve
is possibly becoming defective and not allowing water to dispense.
241509402 Evaporator Fan Motor
I will be here should you have questions, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft....
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
May 02, 2012 | True Freezers
Compressor in fridge not working. Freezer is working fine. Is there a reset button? What steps can I take to see if this is a simple issue?
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 04, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
Oct 03, 2009 | Refrigerators
Refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
Mar 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Mar 10, 2009 | True 23 cu. ft. / 651 liter Commercial...
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
True T-49 Side by Side Refrigerator Commercial Logo
22 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
