Question about Garden
Model 917 377590 eager 1 - Garden
22" eagar-1 snow thrower manual
http://www.searspartsdirect.com/
Put in your Model Number and your Parts Breakdown will show you all of the parts.... This was the Easiest One of the day.
Feb 11, 2014 | Garden
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to adjust carby settings after rebuilding. McCulloch Eager Be
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 01, 2010 | McCulloch Garden
Fuel mixture for Eager ****** 2.0 CID
40:1 is the proper ratio of fuel to oil mix. Mix the fuel and oil in it's own can and be sure shake the can thoroughly just before filling the saw each time. Be sure to use a modern synthetic oil made for saw use and fresh gasoline. Hope this helps!
Jul 02, 2010 | Garden
Eager beaver 60012312 fuel to oil ratio
to be safe always use 25 to 1 on anything
May 09, 2010 | Garden
Looking for a manual on a Craftsman Eager-1 lawn mower. Model #131.90300. Sears has discontinued the manual
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Aug 11, 2009 | Craftsman Garden
Cant start model # 917.377590 a 6.75 hp eager 1 craftsmen mower
I want you to empty the fuel tank. ues a dowel rod to push a t-shirt type cloth in the gas tank and **** out all the gas and water from the tank. It worked for me hope it helps you also.
Aug 03, 2009 | Garden
Tecumseh Sears Eager-1 6HP mower will not start.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Jun 29, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
