Question about Dell Inspiron 1525 Notebook
Error code 2000 0322
Cant adjust display
  • Official Brand Answer
  • 560 Answers
Lbrepntnb,
The error represents you will need to replace the backlight bulb (or the display panel). You can contact Dell Spare Parts Department at 1-877-717-3355 to check prices for the replacment. For information on how to replace it please click the link below.
How to replace the backlight lamp on your laptop
http://dell.to/18CRCOa
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jul 24, 2013
SOURCE:
Cant adjust temperature
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
Nov 29, 2013 | GE CustomStyle PSC23NSTSS Stainless Steel...
Lenovo G480 cant adjust screen brightness! please help
On AC or Battery? As I'm sure you know, your Laptop will dim the Display on Battery to save power. In Windows 7, Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, set Display time, set Sleep and Hibernate to Never, select Change Advanced Power settings, scroll through each one by one and adjust. OR right click a open spot on the Desktop, select Personalize, left bottom select Display. adjust to your preference.
Apr 16, 2013 | Lenovo G480 218422U Dark Brown 3rd...
I adjusted the color on my Display settings and now I can hear but cant see out of range Megahertz?
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 11, 2012 | HP Computers & Internet
I cant figure out how to change the tv from 480p to 720p.
The video resolution is not adjust at the TV, the video source will dictate what the TV will display, 480p in = 480p display, if the source is not 720p, it will not display 720p. It works the same way as you PC monitor, you adjust the PC video setting at the PC not at the monitor.
Mar 10, 2011 | Dynex Televison & Video
Cant seem to make the icons smaller on display packard bell easynote tj65
If you are using Vista/Windows 7 Right click anywhere on your display and you should get an option under view to change the size of your icons or you could change the display ratio/screen resolution which will automatically adjust icon size the higher the display setting the smaller the icon.
Jan 11, 2010 | Computers & Internet
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Apr 28, 2008 | AOC 7F 17" CRT Monitor
1998 kenwood detach.face cd/player
Adjust the time manually.
This adjustment is available only when the automatic time
adjustment is set to off. (page 30)
Display and setting:
Select the display "Clock Adjust" during the selecting function
in the menu system.
Hold down either the 4or ¢button for one second or
more to enter the Manual time adjustment mode.
The time display will blink.
• Adjusting the hours
Press the FM button to advance the hours, or press the AM
button to make the hours go back.
• Adjusting the minutes
Press the ¢button to advance the minutes, or press the
4button to make the minutes go back.
Press the MENU button to end the Manual Time Adjustment
mode.
Exiting the Manual Time Adjustment mode would start the
clock counting.
Hi this is not from the model listed. as i cant find a user manual for that model. but its worth a try :)
Mark
Blue ICE
Feb 26, 2008 | iLO XM-MP3-CD Car Stereo
Change the time
1 Select Clock Adjustment mode
Press the [FM] or [AM] button.
Select the "CLK ADJ" display.
2 Enter Clock Adjust mode
Press the [4] or [¢] button for at least 2 seconds.
The clock display blinks.
3 Adjust the hours
Adjust the minutes
Press the [4] or [¢] button.
4 Exit Clock adjustment mode
Press the [MENU] button.
Hear is the complete manual.
http://inform3.kenwoodusa.com/manuals%5CKDC-MP225.pdf
Nov 20, 2007 | Kenwood Sirius KDC-MP225 CD Player
Dell Inspiron 1525 Notebook Logo
54 people viewed this question
Clive
Clive
Alun Cox
