Question about LG Lp1311bxr 13,000 Btu PortabAir Conditioner
Not working totally ...no power - LG Lp1311bxr 13,000 Btu PortabAir Conditioner
My tab totally off....
Please describe more , you say when you press the volume button down then push power button to turn off screen, then you turn on again , and it doesnt work , what doesnt the phone or the function
Apr 22, 2014 | Samsung Galaxy Tab 2 7.0
What do i have to know about watts in order to work out each appliances power usage aday
Add up all the wattages of the appliances you are using when they come on and go off including lights. fridges. freezers, fans , stoves, tools and every thing. add them all up and you will get thousands of watts called kilo watts . see how many you use per hour and you will get a kilowatt/hr usage rate. Find out the power cost per kilowatt/hr and multiply the usage by the cost and you have your answer. Or you can get a wireless transmitter that is clamped around the input line to your premises and it transmits to a receiver to inside your house (mine sits on the fridge) and it tells you the cost as everything is running . press the mode button and you get progressive cost and other modes are there as well. It is great because if I forget and leave the pool running I can see at a glance that something drawing a lot of power is running so I can check it out and turn it off. Ask you power provider about it or a good electrical shop.
Oct 07, 2013 | Computers & Internet
2008 caravan power sliding door not working
The 30A fuse J11 in the totally integrated power module (TIPM) protects the driver side power sliding door module. The 40A fuse J3 in the totally integrated power module (TIPM) protects the left rear door module. If these two fuses are good, the modules may be defective.
Sep 10, 2012 | 2008 Dodge Grand Caravan
My royter delink 602 stopped working
Check all lights are working.
If totally dead, check wires connected OK.
Reset with pen tip or opened out paperclip while holding power in.
All lights will stay on for 10 seconds then it should reset.
If totally dead, still, check fuses
Jan 03, 2011 | D-Link Computers & Internet
I have HP PavilonDv4000.My batery show charge 96% total time remaning 5min.I have new battery first chrge the battery fully.Second,discharge the battery completely.And this battery can't be charge any...
Try another known good working battery and if it doesn't charge and hold the charge properly,
If that doesn't work, try another know good working ac adapter to see if it is actually charging the battery properly.
If that doesn't fix it then you know for sure at that point the motherboard is bad.
May 31, 2010 | HP Pavilion zd8000 Notebook
My kenwood ka-128 amp keeps randomly shutting off. what can i do to stop it from shutting off? Do i need more power?
you can calculate power needed as follows:-
amplifier power must be 20% more than the total power of all speakers(if total speakers power is 100 watt)you need amplifier of 120 watt at least more is ok.
Dec 04, 2009 | Audio Players & Recorders
Porter Cable Plane totally dead after working a minute
The power switch may be dirty. Try blow it out with air and or solvent.
Jun 23, 2009 | Porter Cable Tools & Hardware - Others
ML 121 RT doesn't power all lights on the system
Go back to where the lights are working, Then inspect the cable leaving that point. You must have a bad spot somewhere after that point killing the voltage.
Jun 18, 2009 | Intermatic Malibu 121W Power Pack...
Totally dead
unplug the power from the back, take out the batteries, and push the power button for 5 to 6 seconds. Wait about a minute, then put the batteries back in and plug in the back
Jul 16, 2008 | Everex StepNote VA4103M Notebook
Red power light on, making a noise but won't switch on/off
hi dear customer. add fast check the electric power and voltage. latter , cheking jumper on the main board, total main boart opening the cacing out,servising total main board.
Jan 14, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
LG Lp1311bxr 13,000 Btu PortabAir Conditioner Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
