Question about Raymarine Type I Linear Drive M81130
Leaking hydraulic fluid
Brand new linear drive, just got today, pull arm out for mounting, hydraulic fluid began leaking out end.
    Sergeant:
  • 415 Answers
Sounds liek the seal is not seated properly. If it is new and leaking, take it back and ask for a repair/replacement. There should be a warranty in place.
Posted on Jan 30, 2014
Driving today, Why did clutch pedal just die and stayed stuck?
You don't say what car? If its hydraulic operation it may need more fluid and bleeding to get going, but find the leak for the fluid whilst you're at it.
If its mechanical, ie a cable then replace the cable. Most cars with a cable system have a self adjust mechanism either under the dash where the pedal pivot is or at the trans end.
If we knew what car we could help.
Nov 01, 2015 | Cars & Trucks
I bought a TP 4000 chair at Staples today and when you sit in it you immediately sink like the hydraulic cylinder that allows you to adjust hieght is bad. Any ideas??
It could be faulty, but there is a arm under the seat that should allow you to adjust it, exercise that lever, perhaps the valve is stuck.
Jan 02, 2015 | Seat Cars & Trucks
Just replaced hydraulic clutch line a week ago and as I was leaving today I put it in reverse backed out and then when I went to put in in first I wouldn't go and there was a puddle of fluid that's leaking...
Sounds like the "slave Cylinder is leaking. That is the device which the hydraulic line attaches to on the side of the tranny and acts as an actuator for the clutch mechanism
Sep 05, 2014 | Cars & Trucks
1997 audi a4 quattro power steering leak
Usually you can see if the pump is leaking. Most times it's a hose, or in your case, I'd look real close at the rack and pinion unit that's mounted in a hard to see spot under the car. It can be leaking into the rubber boots that are on both ends of the unit, then slowly leaking out while you are driving. I would bet this is the problem as the noise you are describing happens when the system has air in it, and as you work it back and forth, it purges the air.
Dec 03, 2013 | 1997 Audi A4
The hydraulic pump does not shut off and the lift arms will not go down on my d19 allis chalmers tractor.
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Nov 18, 2010 | Dmm Allis Chalmers Tractor D19,d21,210,220...
I have a 1020 john deere and there is hydrolic fluid in the oil put a new power steering pump on 2 years ago when it was doing the same thing Is there a ball or a setting pin that goes on the end of the...
power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
Apr 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My hydrolic clutch has just been repaired all new from master cylender to plate but will not stay bled for more then bout 50 miles what could the problem be
can you see leaking hydraulic fluid anywhere? The principle is very simple The master cylinder behaves like a syringe. You press the clutch pedal and fluid is forced by the master cylinder plunger to the slave cylinder mounted on the side of the gear box. The slave cylinder is like a syringe in reverse so that the fluid pushed into it from the master cylinder causes the plunger to extend into the clutch/flywheel bell housing and engage with the end of the clutch bearing release lever. The slave cylinder has a bleed screw on the top of it to release any air that has got into the system. Ensure that reservoir is full and ensure that a sheet of polythene has not been left under the screwed on cap: sometimes done to prevent excessive fluid loss whilst working on hydraulic systems. Make sure that the hydraulic unions at the master and slave cylinders are nice and tight. make sure all bled points are similarly tight. The only possible remaining places for air ingress (and by default fluid egress) are the cylinder fluid seals on the pistons... get under and look for leaks when you can get a colleague to pump the clutch repeatedly
Apr 24, 2010 | 1993 Nissan 240SX
The clutch is stuck to the floor bord and i cant shift
you may have a faulty clutch master cylinder or faulty clutch slave cylinder- leaking clutch fluid. most of the time both are replaced at the same time which should be recomended by your mechanic, the bolts to the master cylinder are very hard to get to and require the right tool.
you should be able to move car forward by selecting 1st then cranking engine till it starts, gear changes while driving are hard but not impossible. i recommend a tow truck to a local repairer.
Dec 22, 2009 | 1995 Isuzu Rodeo
Avid Juicy five system leaking fluid
Your brake failed and you need to take it to a good bicycle repair shop in your area. Hydraulic brakes on bicycles are not easy to self service as you need specialized tools and the proper replacement parts.
Aug 23, 2009 | Avid Code Hydraulic Disc Brake
Murcielago e-gear leaking
Hi
I expect you have had the problem fixed by now, as I see it was posted on the 27 Dec O8.?
I expect it was coolant that was leaking ?
And this has perhaps shorted the electrics on the transmission ECU ?
Good Luck
Don´t forget to give me a rating thanks.
John.
Dec 27, 2008 | 2005 Lamborghini Murcielago
Raymarine Type I Linear Drive M81130 Logo
77 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
