Samsung SyncMaster 17 in. LCD Television Logo
Anonymous Posted on Jul 20, 2013
Remote control not working
New battery's clean contacts
ernesto cuadra
Level 3:
Top Expert:
  • Samsung Master 12,223 Answers
  • Posted on Jul 20, 2013
ernesto cuadra
Samsung Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080797
Points
34431
Use digital camer or webcam cell phone. the LED from r. control must be TURN ON, see the diagram attached. Otherwise, open the r.control and clean the keypad from dirty, corrosion, oxide, and try again.
God bless youremote control not working - de74b35f-aebc-4fa6-a175-ce135b65d23c.jpg
Remote key control won't work on my 2004 95
use camera digital or webcam cell, touch any key from remote control and the LED must be ON, see the picture attached. Otherwsie open the r.control clean with some solver for to clean contacts from dust, corrosion, etc, clean the contacts battery too, and replace by new ones.
I need a new remote control for a tt 1620 recorder player
did you check the battery compartment for damage, dislocation or any visual oxidation of the contacts?
I've had the problem myself with oxidated contacts. After cleaning and adjusting the contacts, the remote worked fine again ;)
To check if the contacts are located good, just test if your batteries make good contact and are sitting tight between the contacts.
To clean the contacts, if necesarry, take a swap, dipped in cleaning alcohol or nail polish remover and clean the contact surface. Acetone works fine as well, just don't use any other cleaning fluids, because they may make the problem worse.
If the the contacts are seriously oxidated, you can scratch the worst off, with toothpick or a match. Metal objects may scratcj to hard.
Good luck :)
Andre
1helpful
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Westinghouse tv remote doesn't work
1) replace new batteries with the same tipe alkaline
2) see the polarities are wrong
3) clean the contacts batteries with c. cleaner
4) retight the spring contacts batteries with l plier for better contacts
5)open the r. control clean the keypads from dirty, corrosion, oxide and bad contacts.
6) reset the code
7) try again, if the problem persist go to the repair shop TV for fix it.
God bless you
2answers
Remote won't work
1) replace the batteries by new one alkalines
2) clean the contacts batteries very wells
3) retight the springs contacts with pliers, for better contacts.
4) try again, reset the code.
5) open the remote control and clean the keypads with contacts cleaner for diryt, dust, and oxide.
6) resolder all points from board rremote
7) if this not work, you must go to the repair shop TV for fix it.
8) the SYSCOM can be defective. remember they send I.R emission.
God bless you
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
2answers
Blaster is no responding
1) Change the batteries, clean the conctact batteries
2) resolder the wires conctacts.
3) Open the keypads and clean the contacts very well with contacts cleaner
4) otherwise you must go to the repair shop TV
God bless you
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
