Question about Garden
John Deere LX178 engine dies at high rpm
If I run the engine at half throttle or more - the engine dies and I smell gas. I have replaced - fuel pump - fuel filter - gas line - spark plugs - air filter. Anyone have an idea of what to do next?
SOURCE: John Deere L120 appears to run out of gas
This is the most common problem with the L120 I'm told. The pin hole in the gas cap needs cleaning (top and underneath as well). I have replaced mine twice already and have only 140 hrs. on it. Starts right up after cleaning. (My symptoms were identical to yours)
Posted on May 23, 2009
mickey813
  • 472 Answers
SOURCE: I have a John Deere LX173 that won't start. I
WHAT MOTER IS IT
Posted on Oct 02, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
I have a John Deere 155c riding lawn mower. I have replaced the battery, but it will still not start. What should I do next?
Take out the spark plug and smell the plug for fuel, see if its wet/soaked with fuel (meaning its flooded) turn the engine over with the plug removed (no gas/throttle) clean the plug with a wire brush, heat the tip with a gas torch or on a gas cooker & put it back in & give it a whirl.
If theres no fuel smell check to see why not (blockage) & check for a spark (take the plug out & touch it to the engine) but dont hold the plug with your hand as it will give you a zap.
Mezo.
Jun 08, 2011 | John Deere Garden
I have a john deere riding mower model L100 it runs good but after 20 o 30 minutes gas stop going to the engine after it cool down it start running again does this mower have a gas pump
When it dies loosen the fuel cap and see if it will start.If it starts its because the tiny vent hole in the fuel cap is plugged.
Jun 26, 2010 | John Deere Garden
When starting, engine will rev up to 3000 rpm then will die. but you can keep it running if you keep it revved up above 3000 rpm
Things to look for: Could be your intake manifold gasket, throttle position sensor, vacuum hoses, throttle body gasket, idle screw, fuel pump, fuel filter, fuel pressure regulator, or maybe you have a split in your gas tank or fuel line(s) that is messing with your fuel pressure. See if you smell gas back near the driver's side rear wheel.
Good luck, those are things I would search for, I can't promise anything, could be a number of things. You should have a check engine light on.
May 23, 2010 | 1993 Honda Accord
Battery was dead, charged; engine will turn over, but not crank. Spark plugs ok, fuel filter ok, fuel pump ok. When I try cranking, strong gas smell. Mower has 30 hours on it, one and a half years old.
Try taking gas line off pump that goes into carb. Crank it, if gas won't come out, tap on fuel pump. If gas still won't come out after tap it with a wrench. Either replace fuel pump or check gas lines making they are free.
Feb 21, 2010 | John Deere 42 in. EZ Trak Bagger
2001 john deere saber briggs moter smell gas in oil
If you're using ethanol-blended fuel, the ethanol will eat away at the neoprene parts inside the Briggs carb.Going to need a carb rebuild.
Don't run your engine until it's fixed or you could damage it as gas will pour into the crankcase, causing the oil to thin and lose its lubricating ability.
Sep 09, 2009 | Briggs & Stratton Garden
Engine runs but keeps going up and down in RPM model JD 445
Have had to replace fuel line in tank MANY times do to it being split just above pump.Try doing a fuel pressure test on the return hose from throttle body,should be close to at least 40psi.
Sep 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Throttle adjustment for john deere chain saw
The H is for high rpm (Main mixture) and the L is for Low rpm (Idle Mixture). First turn in both screws all the way in and then turn them both out 1 and a half turns. Pump the primer bulb if the equipment has one. Start the engine, once it is idling, turn the L (Idle Mixture) screw out (counterclockwise) from the preliminary setting until the engine speed decreases (rich). Note the position of the needle. Now turn the adjusting needle in (clockwise). The engine speed may increase, then it will decrease as the needle is turned in (lean). Note the position of the needle. Set the adjusting needle midway between the rich and lean settings as in the picture below. Don't touch the throttle during this procedure. Once you have found the best idle speed for the engine then you need to adjust the high rpm. This process is the same as with the idle rpm process but you need the to hold the throttle wide open while you are adjusting the H (Main Mixture) needle on the carburetor.
Please rate this a fixya
May 11, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
