Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 FXDWG only one cylinder is firing
No power. Sounds like 650 Honda! Rear cylinder dose not even get warn after its running for a min. or so. Like its not even firing. Only about 3 hrs on 2nd set of new plugs. Haven't changed wires yet. Removed rear plug and checked and it has spark but not sure if its too weak or not, but there was a spark. Harley shop mechanic said it's probably a bad intake gasket. I sprayed either around intake gasket at jug to check for leak and no change at all in RPM. so I assume no leak, not sure. Not sure if coil can be tested to see if its going bad. I would like to eliminate all options of parts that i can repair or replace before handing it over to a mechanic and paying double for a minor fix. Any suggestions of where to go next would be greatly appreciated. Thank you
SOURCE: NO REAR SPARK
I had almost the same thing happen on my 03 sportster it was the ignition modual dont know what year yours is but 03s are bad about messing up harley said they fixed the problem on the replacements
Posted on Sep 02, 2008
SOURCE: Rear cylinder not firing
95 Evo, new plugs, new wires, started backfireing like a machine gun, front cyl. no spark at plug sometimes - would this be the coil, have not ohmed the coil yet . Thanks
Posted on May 13, 2009
v2iper
  • 150 Answers
SOURCE: 1999 Fatboy backfiring & no spark
The guy with the same problem..Your leaving your enrichner (choke) out thats where the 2000rpm and soot comes from...Original fellow I think you may have an intake leak around your manifold or carb.
Posted on Jun 14, 2009
wd4ity
  • 4565 Answers
SOURCE: no fire at the plugs, battery fine, was running
Your Sporty has a fuse box somewhere. check the fuses to see if any are blown. Harley always puts their ignition systems on their own circuit. If you don't find anything that way, contact me directly at wd4ity@bellsouth.net and I'll scan a trouble shooting chart in and send it to you. There's more to the late models than there was with the early models.
Posted on Apr 21, 2010
  • 11800 Answers
SOURCE: i was riding up hill
The ignition is generated simultaneously in both cylinders: if you get it to a cylinder it means that the coil and the electronics pack is operational = the defect is located after them.
So replace the sparkplug - it might be shorted. If you still don't get spark then the spark wire for the rear one is interrupted - replace it.
Posted on Apr 03, 2011
Why dose engine backfire through the carb
https://www.google.com/search?btnG=1&pws=0&q=what+is+the+queens+middle+name
May 26, 2014 | Honda VT 1100 C Shadow Motorcycles
2003 Honda shadow VT1100c the 2 rear cylinders are not firing removed plug they are wet checked fire show firing as good as the front cylinders can pull off plug wires on the 2 rear cylinders no change...
An internal combustion engine requires (3) three things to run(assuming all the internals are good).:
1. A properly timed spark
2. Adequate compression
3. Proper fuel/air ratio
Start eliminating one at a time, until you find the one that is missing...then you have diagnosed your problem. This is how a professional diagnoses a problem.
Sep 29, 2017 | Honda VT 1100 C Shadow Spirit Motorcycles
1984 Honda 650 Nighthawk install camshafts
Hi, Scott you got something wrong double check cam chain alignment and valve clearance for this scenario you will need my service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 Honda 650 Nighthawk camshafts timing marks Google Search
Honda Nighthawk 700s cam timing mod
1984 cb750 cam timing
https://app.box.com/v/motorcyclemanuals/file/1091225383 Free factory service manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB650 Custom Owner Manual
Jul 01, 2017 | 1984 Honda CB 700 SC Nighthawk
I have a Honda Vtwin HF 2417 ride on mower. After about 1-1.5 hrs of mowing the engine starts to splutter and loses power. Within a further 10 mins it cuts out and won't restart. If i leave it for...
you will need to do a cylinder leak down check, preferably when it is hot to see if a valve is getting exceptionally hot causing it to lose compression
Feb 16, 2013 | Honda Garden
Honda valkyrie vacum diagram
Sounds to me, if there is nothing mechanically wrong with the carbs (carbon build up, broken choke spring), that they need to be synchronized. You'll need a vaccuum gauge and some aquarium tubing and a lot of patience. I'd check the spark plug condition to verify what cylinder it is. If it is indeed cylinder 3 (factory set carb), it will be either choke spring is broken or jets are clogged up with bad gas or dirt. For instructions on synchronizing carbs go here: http://www.valkyrieriders.com/shoptalk/carlsync.htm
I've been there, done that.
Oct 18, 2012 | 1998 Honda F6 C Valkyrie
No spark to rear cylinders runs good and then runs on one cylinder 1986 honda shadow 1100
try switching the position of the two coils, the plug wires will unscrew off of the coils and that way you dont have to pull the spark plug wires too,(be sure and change the 2 wire couplers too) if your front cylinder stops firing you know its the coil, if the back cylinder still doesn't fire then your coil is good and you either have a bad #2 spark unit or a bad crank pulse generator.
Aug 05, 2011 | 1998 Honda VT 1100 C Shadow Spirit
2004 v star 650 back cylinder does not fire
Hi, Lenbart1961 you are not getting fuel to the rear cylinder or it is not timed correctly for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/49-v-star/12250-rear-cylinder-not-working-05-vstar-650-a.html
Will not fire on rear cylinder Yamaha Star Forum
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jun 23, 2011 | 2004 Yamaha V Star Classic
Engine misfire
Check the coilpacks, coil leads and clips for shorting or,arcing ( Fire the bike up in the dark and have a look). There are two coil packs so try swapping them and see if the fault changes cylinders, that will isolate the problem.
Mar 20, 2010 | 1982 Yamaha XJ 650
Lands Phones Logo
51 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
