Question about Refrigerators
Remove drip tray frigidaire
How do i remove the drip tray on my frigidaire
4 Suggested Answers
  • 1073 Answers
SOURCE: How to remove the drip
what is the model number
Posted on May 05, 2008
  • 323 Answers
SOURCE: Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Posted on Oct 31, 2009
  • 523 Answers
SOURCE: How do I remove the drip tray on ice/water
pull striaght out
Posted on Dec 18, 2009
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
How do I repair/replace the ice dispensing paddle? Mine broke in half! I have a Frigidaire FRS26H5ASB4
The panel comes off some snap off others have a couple screws hidden under the drip tray. After removing the outer panel, you will see some screws holding the paddle in place.
Sep 24, 2014 | Frigidaire FRS26H5AS Side by Side...
Unfortunately I cannot locate the manual but there is a horrible sweet smell coming from the back of the fridge on the outside. The inside smells fine. Where is the drip tray and how do I check for what...
drip tray is around the back you have to remove the lower panel where the compressor is located should be 6-8 screws holding the panel on sometimes it is made out of cardboard other times its made out of metal unplug machine when going inside to see what the smell is some small animals may get caught inside and chopped up by the fan blades hopefully this is not the case for your occurance of smell but it is something i have seen hope this helps
Jul 24, 2010 | Frigidaire Refrigerators
Smell coming from Frigidaire Refrigerator outside the front panel. Can't find a drip pan so what could it be?
You can Remove rear access panel, then you will find evaportor pan built on top of compressor. Make sure the drain is not plugged and that there is some water in evap tray.
Nov 15, 2009 | Refrigerators
Nasty smell in garage.....think its coming from refrigerator
It's either the drip tray which is removeable from the front, or, mice are playing in the drip tray under the compressor. Soak in up, rinse with some ammonia water & repeat a few times. Rinse well when done. Line up some sticky traps behind the fridge. The mice found a playground amd they will return.
Mar 07, 2009 | Frigidaire FRT15B3A Top Freezer...
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
