Question about Garden
Powerstroke pressure washer PS171433 diagram for the gun wand
Can find where the O ring goes. Gun wand leaks.
  • Judy Lewis Jul 21, 2013
    I took the gun/wand apart and will have to do that again and turn on the water. It's leaking at the trigger part inside. Still don't know where the O ring goes?
  • 41 Answers
In European coupling
Posted on Jul 23, 2013
  • 174 Answers
SOURCE: Karcher B302 gun leaking = taken gun apart but I
jeane_m I can e-mail you a diagram. Can you e-mail me? firehead@rogers.com
Posted on Jun 11, 2009
  • 174 Answers
SOURCE: nozzle/wand leak on DP 3900
It sure sounds like the gun is leaking and not the wand. If you have a repair service near you I am sure they wouldn't mind testing this for you.
Posted on Jul 04, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 497 Answers
SOURCE: durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Posted on Aug 12, 2009
dnewcombe1
  • 1564 Answers
SOURCE: pressure washer water leaking from gun
Depending on the manufacturer, you may purchase a rebuild kit for these very inexpensively. It's just a small pack of o-rings and maybe a spring or two. It would be a good weekend job, pretty simple to figure out, I've got faith in you. Thanks Dana
Posted on Aug 22, 2009
How to fix 12POE-150 power washer leaking gun wand
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
May 01, 2014 | FAIP 1500 PSI Electric Power Washer
I have a Sears Craftsman 3.8 hp 2 gpm 1650 psi pressure washer that the gun leaks water at all times. I went to Sears parts and they say that this gun and parts for this gun are no longer available from...
Depending on the hose type, any wand will work on any power washer, you may just need an adapter. Is the wand hard connected to the hose, screw on or quick connect?
Sep 03, 2013 | Washing Machines
My karcher pressure washer 520 M is leaking water from the hand gun
You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
May 22, 2012 | Karcher K2.26 Electric Power Washer
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Leaking water
The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
Jun 18, 2009 | Karcher K2.26 Electric Power Washer
Karcher 2400: Won't stop spraying.
Dear sdadean,
I am assuming that when you said "wand" you mean the "gun". Myself I rarely service guns. But there are types that are serviceable and others that are not. If the brass elbow had 2 stainless steel pins....then this is a gun that you must replace with a new one. And putting oil, is the worst enemy....because oil damages O rings. Now the high pressure hose is fitted inside the brass part by being sealed by a black O ring and a white backing flat O ring. I do not know if these that you saw. Now if the brass has only one pin coming out from the back, this type of gun can be serviceable. Look at the brass at the place where the lance is attached. If you see a hexagon hole, this is a plug that can be unscrewed with an allen key. Behind the plug there is a ceramic seating. Then you find the valve and a spring. If the steel valve and the ceramic seating are damaged, the whole gun must be replaced.
To tell you the truth I usually change the gun and fit a new one, when the machine keeps on going because the gun does not close. I find it the best and the most safe way of solving the problem.
Regards,
Fulltech.
Apr 27, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 Psi
Dear Aliciaashwor,
I am assuming that the problem occurs when the gun is closed. This problem is due to a fault in the spill valve. When the gun is closed, pressure pushes this spill valve downwards and puts off a micro switch. Now this spill valve has "O" rings. If the O rings get worn out, the spill valve starts going up again and switches the machine on. The pressure is built and the spill valve goes down again to put the machine off. And so this goes on....ON OFF ON OFF. The spill valve must be changed. But if you see that you have pressure when gun is open, all you have to do to stop, is switch off the electricity before you close the gun. This can be done as much as you want, because no harm is done. So open the gun, switch on and work. To stop switch off and after close the gun.
fulltech.
Oct 19, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
302 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
