Question about YBIKE 1020065 YBike Explorer Go Kart - White and Orange
Repair parts one of the steering bars broke ....need to now where and how to get a replacement one
Install steering column,on 99ford ranger video.,,shifter broke. or pics
instead of fixing the broken column go to local salvage yard and replace the entire column it should take you about 2 hours to replace it not even that. it is too much of a hassle to fix a broken part in the column itself and the repair will not always help out in the long run.
Apr 25, 2016 | 1999 Ford Ranger SuperCab
1994 horn buick won't stop blowing
There is a part under the steering wheel on GM cars of this era. It is a round plastic part with metal conducting rail. A part on the steering wheel makes contact with the round part. When they touch, the horn blows. Either the part broke or it slipped out of the position. Steering wheel needs to be removed to repair the problem. New part or just reinstall properly. Usually this happens when someone removes the steering wheel to repair another problem. and reinstalls the wheel incorrectly. New part available at Auto parts stores.
Aug 28, 2014 | 1998-2002 Park Avenue Door Lock & Alarm...
How do I fix the parent steer bar on the radio flyer model 48 trike?
I would suggest finding someone who is accustomed to fixing metal equipment. There's nothing special about the trike that requires specific tools or knowledge.
Apr 29, 2017 | Cycling
Steering crossover bar seam split
i think they call it the front axle and yes it can be replaced try sears parts online
Apr 28, 2012 | Garden
Hazardd switch on steering column broke cant stop lights blinkin
You don't need to remove the column off to replace the hazard switch.
1. Take a pair of neede nose pliers and just pull the old one out.
2. Lube up you new one and just slide it in.
The part numbers for the hazard switch are: 15174447 (retails for $16.23) & 15177379 (retails for $18.42). You have to look for the bar code on the top of the turn signal (multifunction) switch. If the number is 26083635, 26083636, or there is no bar code use the 15174447 hazard switch. If the barcode number is 26090641, 26090642, 26096832, or 26096833 use the other hazard switch (15177379). Now these numbers came off of the recall that was for the 2000 & 2001 S/T trucks so they may not work back too far. But I know that one of those switches works back to 96 (and maybe 95).
Thank you for using Fixya and this should take you about 5 min to replace. Good luck
Mar 29, 2010 | 1996 Chevrolet Blazer
Whamy bar broke
It Can be repaired.. and i found some extra parts for it online. try ebay or amazon.
Jan 30, 2010 | EA - Electronic Arts Rock Band
I hit and broke the 'handle bar,' (wrong name for
The local dealer for this is the sure bet.Get in touch with the parts section at the dealer.Your local autoparts store has items such as brake pads and hard mechanical parts but not multifunction switches and electronics.I hope I could help.Get back to me with any questions.
Dec 22, 2009 | 2003 Pontiac Grand Am
My husband heard something snap in the steering column. After this, the air bag light came on & the horn quit working....
something broke called the clock spring. steering wheel will need to be removed to replace this part, but it should not be a very expensive repair.
Nov 29, 2009 | 1995 Lincoln Town Car
Just wondering if i can tow a ford f-150 with 4 wheel drive and with the front tire off the ground or also known as a car dolly or will it damage my truck????? also wondering about my power steering pump...
1. If you disconnect the transmission , no.
2. Either your steering shaft - relatively cheap and easy to replace - or the steering box - expensive and hard to replace - are at fault. How was your luck lately?
Nov 19, 2009 | 1988 Ford F 150
YBIKE 1020065 YBike Explorer Go Kart - White and Orange Logo
486 people viewed this question
Top YBIKE 1020065 Toys Experts
Andrew Taylor
Andrew Taylor
Are you a YBIKE 1020065 Toy Expert? Answer questions, earn points and help others
