Question about Garden
Replacing tension spring
The spring located on the drive belt pully and the spring located on the foot pedal have broken, i have the springs and a new belt, i know where to put the belt pully spring but not the foot pedal spring nor can i find a diagram that shows the position of the 2 springs once they are connected
    Novelist:
  • 212 Answers
If you can find make and model I may be able to help you.
Posted on Jul 22, 2013
  • 37 Answers
SOURCE: BROKEN SPRING
Hi, check under your seat. at the frame there should be a bracket that the rod and spring goes thru and right to the pedal.
Posted on Nov 23, 2008
mowerman1857
  • 389 Answers
SOURCE: ariens 1440h cutting problem
moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
follow the instructions given and you can download a VERY GOOD picture of where it goes
Posted on Sep 29, 2009
  • 396 Answers
SOURCE: My father owns a 1985-86 Wheelhorse Model 314-A
ususally it is the tensione just has to much give it will nbeed to be rreplaced
Posted on Oct 25, 2009
rycgl
  • 1545 Answers
SOURCE: I need to see a
Copy your model number onto this parts and diagrams page for MTD and as you can see from the existing parts diagram, you will have what you need. I would have but I needed the model number.
http://www.partstree.com/parts/?lc=mtd_pro&mn=13AT605H718+%282006%29&dn=6902073C0001
Posted on Jun 12, 2011
Testimonial: "Thanks for the link,"
kel1guy2002
  • 3740 Answers
SOURCE: I have a John Deere
I hear that on the service manual and the springs. Take a look at these decks if you talking about a deck belt and find yours. Then look for the spring routing visually.
http://opebycrigby.tripod.com/decks/jddeck.html
If you need drive belt info look here:
http://opebycrigby.tripod.com/drive/jddrive.html
I would like to know if this was enough info for you so that you were able to re-connect the spring.
Thanks for choosing FixYa,
Kelly
Posted on Jul 01, 2011
What is the part called that goes on top of the pulley were the belt goes through
Is it a drive belt or on the deck? I helped a friend of mine replace the drive belt tension spring on his. It was located just above the drive pully. Was a very stout spring. Used a brake spring tool and it popped right on. Is this the same thing you are talking about? the L shaped piece with a belt tensioner on it? If not, I will get back on here later and try to help. Thanks.
Jun 12, 2015 | Toro Z Master Zero Turn Riding Lawn Mower...
Want stay in timing
If you have replaced the spring loaded belt tensioner ( leave the pully nut loose ) then on refitting the belt , at a point midway between the two cam pulleys there should be a maximum deflection of .37" to .45 " ( 3/8 to just under 1/2") with a 22 lbs load applied on the belt . the tensioner pulley is then tightened up at the pulley nut to 28 -38ft lbs torque setting
Jan 26, 2014 | Mazda 626 Cars & Trucks
How do i replace the serpentine belt on my 2005 saturn relay
Hello carpsupr,
Removal Procedure
1. Rotate the drive belt tensioner counterclockwise to release the spring tension. See picture below.
2. Remove the drive belt.
Installation Procedure
1. Install the drive belt to all of the pulleys except the generator pulley. See picture below.
2. Rotate the drive belt tensioner counterclockwise to release the spring tension. See picture below.
3. Install the drive belt over the generator pulley.
Ensure that the drive belt is properly routed.
Regards,
netvan
Mar 28, 2011 | Saturn Relay Cars & Trucks
What is the drive belt adjustment 11.5 hp ride on mower
The drive belt is tensioned by a spring on the clutch pedal. If you can give me the model of mower you are working on, I can help you find the spring or the variable speed pully.
Thanks, Matt
Jan 15, 2011 | Mtd Garden
I need to see how the dryer belt on my samsung DV448 dryer is routed. It isn't broken, but it isn't taut as well.
It sounds like you have a bad or broken belt tensioner. It is located in the bottom of the unit close to the motor . It is a spring loaded pully assembly which keeps the belt taught. The belt simply goes around the drum and the motor shaft and the belt tensioner pully.
Sep 17, 2010 | Samsung DV448AEE Electric Dryer
Cant ajust tensioner pully
You have a (spring loaded) tensioner. I usually use a rachet and whatever size socket the bolt requires and use a 2 foot hollow pole as a pull handle.. Put the socket and rachet on the bolt, slip the pole over the handle of the rachet and push the tensioner back which will give you the slack room you need to install the belt. Make sure you have the belt around all the other pulley's so it will be a easier to slip it on to your tensioner. This tensioner should adjust itself by spring action.
Jan 24, 2010 | 1993 Ford Explorer Limited
Tension spring and pulley fell off
that seems to be a problem on several types of cars .. the pivot bearing freezes up so the tension spring no longer limits force on the belt .. then the pivot may break at a time of high stress .. you can replace the entire assembly with factory or replacement parts .. then its a good idea to inspect it now and then to make sure its free (pushing on the belt should cause movement of the tension pully .. there is usually a nut on the pully that you can use to move the pully to relieve tension so the belt can be installed ..
Jan 19, 2010 | 1988 Buick Regal
Ford focus 1.6 ghia 2006,a broken coil spring droppeed down on my left foot as i was driving along,i have checked through the haynes book to see if i could get a location point for this spring to replace...
i would venture to say that it is the return spring for eithetr your clutch brake or gas pedal check the haynes book for theier locations and see if one is missing from those pedals
Sep 24, 2009 | Ford Focus Cars & Trucks
Tension pully is loose making the belt rattle
It sounds like you have a broken serpentine belt tensioner. The tensioner should always be tight, it is spring loaded and you would have had to release the tension on it to have put the new belt on.Depending on what engine that is in yours, this could be an easy fix or a hard fix. The tensioner on a 2.2L is made into a large plate bracket that is attached to the front on the engine and several other items have to come off to replace it.The tensioner on the 3.1L v6 is smaller and has one bolt that holds it on.Either one is available at the local auto parts store.
Hope this helps
Apr 20, 2009 | 1997 Chevrolet Cavalier
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
