Question about Viking Refrigerators
Change temperature setpoint - Viking Refrigerators
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Viking Master
  • 102,366 Answers
What model Viking refrigerator?
Posted on Jul 20, 2013
Bryant Furnace starts up then shuts off
If you have a standard thermostat and not a digital stat, the problem could very well be the 'heat anticipator' setting on the thermostat sub-base. It is a variable resistor that has to be adjusted to match the amp draw of the heating control circuit. In the heat mode, the heat anticipator 'warms' up the thermostat because of the heat generated through the system controls and causes the thermostat to 'anticipate' room temperature setpoint just a little before it really gets there.
If set too low, the result is a short cycle, if set too high, the result is an overshoot in setpoint temperature. The average setting for the anticipator is .4. You should see a very thin 'wire wound' flat resistor under the cover with a thin metallic pointer that physically slides from left to right or right to left. The pointer is pointing to its 'setpoint'. Adjust it up .1 or .2 from its current setting and observe operation for a week or so to see if any appreciable change has occurred.
Mar 22, 2015 | Bryant Heating & Cooling
Tip
Service Mode for GE Harmony DPGT750EC
To find out what all of those sensors in your dryer are reporting, you have to enter Service Mode. To do so,
  1. Power on the dryer...or press "Home" if it is already on.
  2. Press "Home" and "Help" simultaneously until the dryer beeps.
  3. Choose your type of drying cycle and begin it.
You will notice on the bottom right of the screen a bunch of numbers. The top number will change constantly because that is the blower speed. If it is not getting up to @2,400 rpms, then you need to clean the blower blades and trap or take the blower motor out and re-solder all of the contacts inside the motor. Be careful and take note on taking apart the motor and putting it back together. Don't attempt this if you don't know what you're doing! Ask for help if you're not sure. And always unplug the dryer before taking it apart!!!
The numbers below that are the temperature setpoint and the actual temperature(air dry will result in zeros). The actual temperature should reach the setpoint unless the blower motor is not running- safety feature. Extra low setting resulted in a setpoint of 42 degrees Celsius? on my dryer, Low setting was 67 degrees C, Medium setting was 83 degrees C, High setting was at 100 degrees C. Other sensors include humidity sensor, vent temperature sensor, line frequency reading under OK VOLT(@60 US, @50 Europe), voltage(200-220) and countdown timer in seconds(last row). If the voltage is roughly half, check both breakers!
I hope this little tip will help you in your repairs!
Ed
on Nov 05, 2010 | GE Profile Harmony DPGT750EC Electric...
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
How to change pressure setting on SG Intellisys Controller 39875158 Unable to change offline pressure 103psi and online pressure 93psi on Controller.Please advice the procedure to do so.If there is a...
For and SG controller use the following instructions to access factory setpoints which will allow you to change the pressure setting. Note : look at the metal data tag affixed to the compressor for the correct pressure setting. (eg: 125 psi) do not exceed the data tag pressure or premature damage to the compressor and personal injury may occur.
To access... Power must be applied to the
compressor with READY TO START showing in
the display.... press the center (MAIN MENU)
display button two times and then press the LOAD
button followed by the UNLOAD button, all within
three seconds.
To change settings... The values of the Factory
Setpoints can be changed using the same buttons
and procedures used to change the Operator
Setpoints. Refer to the Operator's Manual for
details.
To exit... Press either the STATUS or MAIN MENU
buttons. If no buttons are pressed within 30
seconds, the display will automatically return to
the Current Status screen showing Package
Discharge Temperature and Airend Discharge
Temperature
Oct 14, 2013 | Air Tools & Compressors
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
Although I set the desired temperature, it only reads that number for a brief minute then it changes to a much highter number. How can I set the thermometer?
What your seeing is normal. Anytime you change the temperature by pressing the up or down arrow to change the setpoint, it will show you what your current setpoint is. After the keys are idle, basically, your not touching the keypad for 5 to 8 seconds, it changes to the current temperature in the room. So, when you touch the keys, it gives you the temperature you want. When you don't touch the keys, it shows you what the actual temperature is in the room. Your unit is running normal and as designed.
Sep 27, 2010 | Genie Aire PACR9 Air Conditioner
I have a new Dell MX5000 revolution keyboard and mouse. The display does not show the time nor will the temperature change from Celius to Farenheit. The keyboard and mouse otherwise work great.
Your Logitech MX5000 requires their SetPoint application software to make those changes. I you do not have it, you can download it HERE. Once the software is installed, the time will sync with your laptop and the temperature setting can be changed within the My Keyboard tab.
Sep 18, 2010 | Logitech Cordless Desktop MX 5500...
How do i test my room thermostat
To check your thermostat you need to advance the temperature towards the setpoint slowly. You also need an acurate thermometer to see if the thermostat will turn the heat or A/C on when the setpoint is reached. Also check the make sure that the temperature on the thermostat is close to the reading on your thermostat.
Heatman101
Feb 27, 2010 | Kitchen Appliances - Others
Kenmore Electric range does not maintain temperature setpoint.
How do you know the thermo sensor is working correctly when it gets hot?. No I think the thermal sensor is defective, it is cheap to buy.
May 04, 2017 | Kenmore Ovens
Refrigerators Logo
29 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
