Question about Garden
Cycling is not working on my Simoniz S1600 Elecctric power washer
  • 41 Answers
Regulator or manifold
Posted on Jul 23, 2013
3 Suggested Answers
  • 174 Answers
SOURCE: One day it was working fine the next day
It could be the thermal switch in the motor but that cannot be reset. If you used it with an extension cord, this has blown the thermal reset in the motor. You now have a blue boar anchor. If you haven't used an extension cord then it is probably the bypass valve switch. When you use your washer, then let the trigger shut off, this valve shuts off the motor. When you open the machine, you can tell where this valve is because it somehow has a small switch mechanism attached to it.This valve needs to be pulled out and greased with a good waterproof grease. If you can tell me the serial number, or e-mail it to me at firehead@rogers.com, I may be able to get you a schematic.
Posted on Aug 12, 2009
  • 174 Answers
SOURCE: S1600 Simoniz gun - I took it apart and I have a
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Testimonial: "Thanks - a little frustrating thinking there must be a simple fix - buying a new gun that will also breakdown - that's where they get you. "
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Mar 31, 2010 | Garden
Where is the pressure switch located on a simoniz 1600 electric power washer?
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
One day it was working fine the next day nothing.My Simoniz S1600 completely dead. Is there a thermal switch or fuse in it?
Aug 11, 2009 | General Garden
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
Aug 11, 2009 | Karcher Garden
Manual needed for Simoniz S1800 Pressure Washer
I contacted the Company in US.
Thank you for keeping in touch.
Jun 21, 2009 | Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
