Question about Pool & Spa
My pool pump shut off because I think it overheated. I looked in the skimmer basket and there was a plastic bag in it that had blown in off the deck (dh had been installing lights today and didn't clean up after himself.... Grrrr!) It would not turn back on when I discovered the problem and removed it. How long before I should try to turn it on again & know if the pump is ruined or not? We are in the middle of a bad storm right now.. Can't go out to get all the details but it is on a 15x24 oval above ground swimming pool and takes a filter cartridge, plugs into a large twist and lock plug. I've read that some pumps have a built in sensor that shuts the pump down automatically to prevent damage to the motor before things get to hot. I've got my fingers crossed that this is the case.
    Problem Solver:
  • 12 Answers
Your would be correct. Most pumps have a high limit switch that kills the power when the motor gets too hot. As long as you have shut the power off to the motor, wait until it is safe from the storm to go and try it again. They usually cool within 30 minutes. Check the pump basket first before turning it on. If it was running for a long time without water circulating, the heat may have distorted the basket and need to be replaced. If the pump turns on and primes up your off to the races. If not, you may need to replace the seals or the entire pump
Posted on Jul 20, 2013
  • Monica K. Nickles Jul 21, 2013
    Actually, before u heard the sordid news story of me drowning my husband and his uncle in the news over my fairly new pool pump being fried, after a couple of hours of myself cooling off I went out and figured out that the gfs leading to it shut down when it overheated and I hit the re set button for it. Working good enough for now. Close call for an episode of "snapped" I guess...
  • 61 Answers
SOURCE: Pool pump will not fill back up
It sounds like you are sucking air into the pump. Make sure strainer baskets and pump baskets are clear, and the valves are in the right position. Also check the water level in the pool, and make sure that the pump is not sucking the skimmer dry. Next try lubricating the gasket on the pump lid, or if it is in bad shape (flattened/cracking) replace it. If this does not solve the problem put silicone around the inlet to the pump (silicone is a temporary fix that could last days or months--for best results replumb with teflon tape and sealant). If all that fails you could have debris stuck in the impeller.
Posted on Apr 05, 2009
  • 77 Answers
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Posted on Apr 28, 2009
dragonsthatk
  • 547 Answers
SOURCE: lost my prime in my
please check your impellar it sounds like it is broken this is the part that really moves the water if motor is ok then it would most likely be this .
Thanks for useing fixya
Rate me
Posted on May 03, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: NOT FILTERING, NO SUCTION, CHANGE SAND,,,SINCE DAY ONE..WRONG HP?
You are correct. Your lines are extremely small for this system and the pump is to small for this system. You are going to have to do a total upgrade. from the pump to all the lines. I know this is bad news, but it is a common problem for system that where put in more then 10 years ago
Posted on Jun 01, 2009
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
I have an Intel pool (4ft18)Iam looking for a square lid that covers skimmer basket so I can vacuum my pool do they make one?
I would contact a local pool supply center, they are you best bet to find what you need.
Sep 22, 2016 | Pool & Spa
How do I stop my swimming pool from leaking water?
id look 4 a leak someplace in the suction side of things when pump runs it draws air in hole so No leak but when pump shuts off No draw just water and it leaks out
look for hairline cracks in skimmer bottom and bottom suction lines , Might require scuwba equipent to see ?
Nov 03, 2014 | Pool & Spa
I have a pentair cartridege pump for my inground pool. In the skimmer basket there are 2 holes.one to the pump and one to the main, it looks like the one to the main has something blocking it. on the
all inground skimmers have 2 holes some pools use the front one for a equalizer that is if you pool water gets low the skimmer will still work if no hole in the side below skimmer it will be plugged sometimes pool builders mix them up and use the back one for the equalizer like I said if no round hole on wall below skimmer just disregard
Jul 06, 2014 | Pentair Pool & Spa
Hayward pro series sand filter does not have enough suction to operate pool cleaner. What can cause this?
if you are getting a suction noise at the skimmer then that means you need more water in the pool. Also if you have anything in the skimmer basket like tablets then take out the basket when you are using the vac. the only other thing I can think would be the problem would be the filter is clogged. I know you have back washed it but I would do it again to be sure it is not dirty. good luck
May 26, 2014 | Hayward SAND FILTER, PRO SERIES
Polaris 3900 wheels won't turn
check inside see if belts or hoses came off
Oct 20, 2012 | Polaris 3900 Sport Pool Cleaner ()
I cleaned my Pool filter element and need to precoat it with diaomite earth, how is it done. The chart said I need to use 6 lbs. do I put the earth powder in the skimer?
Yes. Clean your baskets, then with the pump on and the baskets in place slowley put the powder in the skimmer. Ether straight from the bag or mixed in a bucket of water. Just be sure to go slow so it dosen't clog the pump while going through system.
Jul 29, 2010 | Hayward SAND FILTER, PRO SERIES
Will a 240 hayward sand filter with the SPX0710X32 valve, allow
If they are to much for the pump basket you can try filter by-pass. Another thing could be a tool called a leaf master that hooks on your garden hose and sweeps any and all light stuff from pool and collects in a bag big enough to hold it all in one sitting.
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
Retrofitting old pool. easiest location for electronic sensor is at negative edge. Is levolor k-1100 the right one to use?. Thanks .Marty
If you have an expansion joint behind your skimmer you can feed the cord through the hollow joint if you chip a small amount of deck from ether end and then mount your sensor in the skimmer just be sure your basket will clear it and mount it so it reads when the pump is running or you will overfill the pool constantly.
Oct 10, 2009 | Pool & Spa
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
137 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
