Sony bravia kdl 46xbr
My Sony KDL-46XBR is getting vertical green stripes. What is causing the problem
    Top Expert:
  • 12,223 Answers
You must test there poor connection, and particle inserted.in LVSD
SEE THE DIAGRAM attached.
God bless yousony bravia kdl 46xbr - ac130af0-fc3d-4eda-b049-1a2638316c42.jpg
Posted on Jul 20, 2013
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 668 Answers
SOURCE: sony bravia kdl-32l4000 has colored vertical lines
Most of the time the " T-Con" board is the cause. On a lot the Sony models, this board is not replaceable without replacing the LCD Panel. Sony has been making more of them available but you would need to check with Sony's Parts Department if it is available for your Model.
I hope this helps,
Sky Assoc
Posted on Jan 05, 2010
SOURCE: Sony BRAVIA KDL-46XBR 46 in. HDTV LCD
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Posted on Feb 04, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
I have a Sony KDL-32BX300 showing vertical lines. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 30, 2015 | Sony Bravia KDL-32BX300 32" 1366 x 768...
I have a sony bravia tv which i have had about eight years. four vertical lines have appeared in the bottom right hand area of the screen. one long red line one long green line. and two short lines on...
Jan 18, 2015 | HCDZ General Remote Control Fit For Sony...
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 03, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
The tv goes dark on one side sony 46
Had same issue with kdl 46xbr5 (service manual lists this model and your model in the same manual).
I loosened and retightened all of the ground screws until I found the one that caused the problem. I also reseated all of the cable connectors (with the unit off) before I did that as well. Found a few connectors were loose and at least 3-5 ground screws were not tight. works just perfectly now.
Mar 22, 2013 | Televison & Video
Sony BRAVIA KDL-46XBR 46 in. HDTV LCD Television. I have a problem when the unit is switched on. The screen has 2/3 lines running across it. The picture stays like it for about 10 mins then goes back to...
I hope this helps
Jan 19, 2010 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
What is the TV Code KDL-46XBR
Typically, this is the model number for a Sony 46 inch Bravia XBR television.
Mar 29, 2009 | Bose Lifestyle V20 System - black Theater...
I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line on left side of screen
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
