Question about Baby Gear
I need battery pack and battery compartment cover
I have lost the battery holder and white battery compartment cover and now I cannot use this at all. Any suggestions on where I might find these??
    Problem Solver:
  • 8 Answers
Go to the companies website. Many companies like Fisher Price offer replacement parts quite reasonably. Just put in the model number or name in the search bar on the companies site. If the parts are discontinued, the best place to look for replacements is ebay or craigslist. Best Wishes!
Posted on Jul 30, 2013
How do I access the light meter battery compartment
Battery holder is under bottom cover. Remover large silver screw. Clean battery holder in case of leakage
Sep 13, 2014 | Nikon N2020 35mm SLR Camera
Tip
How to reset Nintendo DS Lite.
Remove the cover for the battery compartment. At the back of the DS Lite, the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
Put the battery pack back. Just line it up in the compartment and push it back into place.
Replace the cover. Replace with the screw.
Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
on Feb 12, 2010 | Computers & Internet
Have pair of FRS14ND radios, with charger. One battery pack has quit, so other must be about to. Tried switching remaining pack between radios & both work, so it's not radio. Can't get AAA alkaline...
Similar problem, solved when dirty contacts were cleaned, look for some corrosion on either the battery pack or in the radio battery holder. Use very fine grit sand paper.
also check to see if a tab on the battery holder contact is bent inward (radio dropped perhaps)
Jan 08, 2011 | Columbia Telecommunications Group...
How to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    How do you restart nintendogs
    No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
    Feb 12, 2010 | Nintendo DS Lite
    Rechargable Battery Problem on Kodak DX 4530
    Inside the battery compartment, on the same side as the battery cover hinge, you will see a small white mechanism. As I understand it, this is a microswitch which recognises when rechargeable batterys are installed. I suspect this may have been damaged. If so, you will need a rock-steady hand and brilliant eyesight to repair it. Even dismantling the camera is a challenge.
    docramage
    Oct 06, 2007 | Kodak EasyShare DX4530 Digital Camera
    Maintain all-weather capability
    The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
    Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
    All-weather
    Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
    All-weather capability
    The following steps can be taken to maintain the all-weather: Make sure that all the covers are closed before using the camera. The camera loses its all-weather capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Saltwater spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. If the rubber packing becomes worn or damaged, contact the nearest Olympus service center to obtain a replacement part.
    Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
    Maintain all-weather capability of my camera
    The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. •Wipe any water off the camera before changing the battery or card. •If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. •Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. •If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. (A charge is made for replacement of parts.) •If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover, otherwise water may get inside the camera. •The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
    Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
    Baby Gear Logo
    121 people viewed this question
    Top Baby Gear Experts
    Dorel UK
    Dorel UK
    Jennifer Rock
    Jennifer Rock
    Are you a Baby Gear Expert? Answer questions, earn points and help others
