York model h1da024so6a
Can hear it hum when powered but fan wont spin unless I push start it with a stick then it runs but wont blow cold air, furnace filter was real dirty and may have inhibited air flow, how do I fix?
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have a york furnace
Kill power to the unit. Replace the filter or clean it up real good. Then turn it back on after 30 minutes the board should reset.
Posted on Jan 09, 2011
The AC makes a humming sound when starting the fan. If I spin it by hand it runs. Model 620315.321 serial 90716722.
The humming sound is the motor trying to start, if you turn it by hand, usually they will run. it sounds like the motor for fan needs cleaning and oiling. God-Bless ya all!
May 20, 2016 | Dometic Rooftop RV Air Conditioner
Took off back to see filters put back together now wont start. spark,nozzle and fan work it just wont start
My Furnace Won't Start. Any Tips Before I Call for Service?
www.airmasterheatingandair.com/my-furnace-wont-start.-any-tips-befor...
Jan 30, 2013 - When your furnace will not start, you might feel a sense of panic and ... GA furnace repair specialists, our team at Air Master Heating and Air has ...
Furnace Won't Turn On? Furnace Troubleshooting
asm-air.com/heating/furnace-wont-turn-on-furnace-troubleshooting/
Jan 7, 2015 - It can be frustrating when your furnace won't turn on, not to mention ...but when you start moving up north it can be downright dangerous when a ... If your furnace is turning on, but blowing cold air, try: Heater Blowing Cold Air.
How To Fix a Furnace that Won't Start - Bonfe's - YouTube
? 1:52
https://www.youtube.com/watch?v=g5alqU4OvqA
Jun 15, 2012 - Uploaded by bonfesplumbingHVAC
Will your furnace not start? Before you call a professional heatingcontractor, check the following step-by-step ...
Furnace wont start. What to do before calling the repa
Jan 16, 2016 | Heating & Cooling
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
York diamond 80 fan starts running blowing cold air before furnace ignites..replaced thermostat
OK so you replaced the Thermostat huh? OK well then did you also replace the Thermistor Temperature Sensor? or whatever is used? As often it's BOTH, also check the wiring from the sensor to the host, in any event if it's NOT that then all it can be is the controller board, most likely the Micro? Check any and all sensors first though.. try to get a service manual too, it's hard without one?
Oct 20, 2011 | York Furnace Draft Inducer Blower Fasco #...
My air conditioner will not Start on it's own. Then temp controller in house makes a click sound, the furnace fan then runs like it should. But when I go outside I hear a buzz and click sound like it's...
compressor locked up. try hitting top of compressor with a block of wood on top and a hammer, wait a few min. then turn on. if it dosen' start u will have to replace it.
Aug 06, 2010 | Heating & Cooling
Induced Draft Blower Not Blowing- 3 Blinks on LED
Your doing well just right. When the call for heat is on the draft motor gets a call from the board to come on. When this happens if no voltage is present at the motor then you ahve abad baord. Replace it.
Nov 28, 2009 | Heating & Cooling
Compressor makes noise, but fans won't run
I'm guessing the hum you hear is the fan motor. After sitting for a time, I've had many that develop like a dead spot in the fan motor. Here's what to try. Shut power off to AC. Get someone up on the roof with about a 2 ft.,long fairly strong stick, or rod , about 1/4 inch or so in diameter. Have them carefully poke it through the openings in the cover and spin the fan blades at the back end of it. May be a little stiff at first, so don't break blades on fan, but get stick under one & lift to spin it, or over it & push it downward. Spin it 2 or 3 times all the way around. Turn power back on. Now stand back & try fan mode again. 99% of the time that will do it, but if not, take screws off around cover on roof & remove cover & give fan a bunch of good spins by hand, then turn power back on & try it. Keep me posted on results please ?
Jul 12, 2009 | Dometic Rooftop RV Air Conditioner
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Blower motor hums but wont start
Check motor capacitor and try spinnig blade or wheel to see if spins freely if doesn't then the bearings are bad in motor and needs replaced
Apr 09, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
