Question about Qca Spas Pool & Spa
How to reset temp limeter
My temp stays at 100 I cant change it
    Problem Solver:
  • 21 Answers
More info, maybe I can help
Posted on Jul 28, 2013
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
Cant figure out how to get back to farenheit temp..
to change between fahrenheit and celsius
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit. To remove, press UPPER OFF,
LOWER OFF or OFF/CANCEL. you can click on the link for guide http://www.ajmadison.com/ajmadison/itemdocs/8300609.pdf
Aug 16, 2008 | Whirlpool GBS277PDS Electric Single Oven
I borrowed a portable a/c unit Comfort -Aire model number PD121-5 cant get it 2 stay on cool it has timer & changes temp all the time. can anyone tell me how to reset this thing? No remote
some ac units portable or other wise use a program where it starts on full cool and as the humidity is removed from the room the program changes to less cool or switches off for periods ( called comfort mode on some units and is used for sleeping where the room temp is maintained and does't get colder as the night goes on)
try and down load a operators manual from the net
Jun 29, 2015 | Heating & Cooling
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Mar 07, 2015 | KitchenAid Ovens
2003 kia spectre cat and evap wont reset
You need to drive the car at least 50 - 100 miles in both city and highway driving at normal operating temp before the system will reset.
Feb 24, 2014 | 2003 Kia Spectra
What does the percentage mean regarding my oil
oil life. 100% means you just changed oil. 0% means the oil is worn. the computer tells you when to change oil based on hours run speed acceleration and engine temp. Id change mine when it says 10% because at 0% the oil is toast. when you change the oil you need to reset the cluster so it reads 100% most lube places do this for you. if not read the manual it tells you how to reset
Mar 15, 2013 | 2007 Chevrolet Tahoe
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Change engine oil message stays on
the Change Engine Oil message is diplayed in the driver information center when the oil change is due ,,,,, to RESET display message , press the INFO button to display the ENGINE OIL LIFE message , ,, Press and Hold the RESET button untill 100% ENGINE OIL LIFE is displayed.
Dec 23, 2008 | 2001 Cadillac DeVille
Pool & Spa Logo
50 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
