Question about Refrigerators
SAMSUNG SRL324NP Can you set the fridge-freezer to factory settings? The display lights are almost non-existent now and I can't tell what the settings are. The fridge is too warm and the freezer is icing u.
catriver
  • 878 Answers
SOURCE: freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Posted on Aug 28, 2006
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
  • 57 Answers
SOURCE: WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Posted on Oct 20, 2008
  • 2418 Answers
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
Samsung Fridge/freezer problems
The BBC has an open complaint on these machines and you may be elligible for extended work on this
Feb 20, 2014 | Samsung RS2630SH Side by Side Refrigerator
I have a 3yr old samsung fridge/freezer srl324np. this morning i woke to find the digital door display flashing, and the inside of the fridge was warm, however the interior light was still working. i've...
It sounds like a temperature sensor problem. On my RF265AABP model there is a control board located under a cover on the back of the refrigerator. There is a wiring diagram on that cover. Remove the cover if you have one, and locate the control board and power supply boards. If you have a voltmeter, check for +5V and +12V (on my model anyway) from the power supply board. If that is OK, then check the voltages on the temperature sensor wires. Mine are at the bottom of the board as shown in the photo. I have 5 temperature sensors, refrigerator (R), freezer (F), refrigerator defrost (R-DEF), freezer defrost (F-DEF), and Pantry (a temperature controlled drawer in the refrigerator). You may need to refer to your specific diagram to get the colors of wires, but it appears that the voltages should be somewhere between about 2 to 4 volts from each sensor to ground. I had a broken ice maker wire that resulted in a high reading, about 4.3 volts on the freezer sensor, so I assume high reading indicate an open sensor, and low reading indicate a shorted sensor. I am not sure where the refrigerator sensor is located. Repairing the broken wire restored the display to normal readings.
On my model the left gray wire is common, and the diagram should indicate color and a letter or so (R, F, R-DEF, F-DEF, Pantry) on my model.
Sep 12, 2013 | Samsung Refrigerators
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
I cleaned my fridge only with paper and cloth towel last time. Ever since, the freezer is working but fridge completely shut down. I tried to switch on and off. The light is on in fridge but it's not...
It's not the compressor otherwise the freezer would not be working either. You might first check to see if the settings are set at the factory indicated settings, if the freezer is turned up to cold this will shut off the air flow to the refrigerator.
May 17, 2011 | Samsung Refrigerators
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
http://safemanuals.com/314159.php?k=2f8f21dfdc6e62cb4825d07d38bad88d&ID=471000&q=SAMSUNG%20RSH1NHMH
Nov 18, 2010 | Samsung Refrigerators
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Fridge light and temp settings off.
hi
it may be the problem of of timer,thermostat or compressor,,check it//thank u,,
please rate it
Jul 04, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
