Question about ViewSonic Optiquest Q19wb LCD Monitor
Help desk Out of frequency message. This comes up for several games and nothing else. It is not a problem with my video driver. It seems that the games are switching frequency and I lose my picture. It goes blank and a "Out of Frequency Message" appears. Is there something to change that I'm not seeing?
  • Robert Trimble Jul 19, 2013
    Note that pressing "auto" does NOTHING. The monitor light goes from green to yellow and no button does ANYTHING.
    Master:
  • 663 Answers
Check the directx if it's up-to-date or not. It might be the reason why you are having this issue. Or it could be that there is a driver that you need to update. To make sure that it's not a driver problem, I suggest that you scan your computer with RadarSync. It's a PC driver updater.
David
Posted on Jul 21, 2013
3 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: a_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Posted on Feb 08, 2008
babes_ganda0
  • 381 Answers
SOURCE: Sonicview VG 2021 - Out of Range message
..hi..just select menu on the front panel of LCD the find the option Auto then click Auto..good luck..Thanks...^_^
Posted on May 11, 2009
Windows 7 64 bit Ultimate SP1. Nuendo 4.2.3. 32 bit version. Delta 1010 LT Sound card. Just out of the blue I started hearing slight crackle when playing back videos, wav files etc etc. It seems to do...
you might have to remove the sound card and make sure the socket is free of dust restart your computer then reinstall it
windows 7 should automatically find the drivers and install them
click start right click on computer select properties in the left hand panel device manager scroll to
sound and video game controllers if you see a yellow qustion/exclamation mark ? ! or a red X
a newe driver will need to be reinstalled
hope this will help
Sep 25, 2011 | M-Audio Delta 1010 Sound Card
Screen says "OUT OF RANGE H:27.8K V: 62.0
That's the monitor telling you it's getting a signal it can't handle. The H and V values are the horizontal and vertical frequencies that control the display. They change depending on your computer's video card settings. The monitor can be damaged if run at frequencies outside its safe range, and it displays the message you're seeing to protect itself.
Start your computer. When the manufacturer's splash screen (logo screen) comes on, press the F8 several times. This will get you to a startup options menu. Select "Start in VGA mode" from the list. Windows will start up then with settings every monitor can handle, and you'll be able to see again.
You might have a game or other graphics application that changes video settings to something the monitor can't handle. If this is the case, and those settings are required, you'll need to invest in a monitor with a greater settings range.
Feb 04, 2010 | Hyundai ImageQuest QV770 17 in.CRT...
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
Booting up windows, now receiving "HID DATA has stopped working" msg respond "check online and close program" message box goes away and laptop seems to work fine anything to worry about? OS: windows...
Hi. HiD Data is basically a control driver base located in the system 32 file bank. these drivers control mouse, game controllers and keyboard functions as well. Usually when this message box comes up, it is signaling a sudden change that may have occurred during a failed boot session or, sudden changes in the windows system 32 file base. these sudden changes can happen when there is a windows update that isn't quite compatible with the current version of one or more of the HID driver components or, if the OS has experienced a virus hit or , malware.
This may not be an issue at this time but, if the message box frequency level increases, i would recommend reinstalling the OS by using the repair option or, the restore feature.
Jul 20, 2009 | Computers & Internet
I have an intel 82845G/GL/GE/PE/GV graphics controller. Games that used to work well now they don't run anymore. I get a black screen with a message ''H.V. Frequency overrange'' and the Pc shuts down....
reset you video settings. try to lower frequency settings or start setting to default VGA mode then try moving to 800x600 resolution then up.. 'hope this helps
Jul 10, 2009 | Computers & Internet
Nvidia 6200 agp will not play games on s video
What Monitor settings are u using? Try higher frequency & if its a 17" monitor use 1024 x768 setting(resolution) and frequency 75-80 Hz. Also check the nVidia website for driver update for this model. I recently saw that there is a new driver in this category!!!!........sodeep
Mar 24, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Event error 1033
it seems like this problem may be related to your video. I found this forum about the same problem and it seems there are several different reasons. You can try to load new drivers for your video card (search your computer brand and model + video drivers) and see if that helps. Other than that you can try one of the solutions offered in the previous link
Jan 07, 2009 | Acer Aspire™ T180 PC Desktop
Barbie iDesign Ultimate Stylist Game not working
Try updating your graphics drivers from the internet for your video card. Since the minimum requirements for this game is a 32 MB video card, your video card should work just fine. Attempt to update the graphics drivers from ATI's website. Also verify that you have direct x compatable sound card, which is also required for this game.
Dec 09, 2008 | Video Game Consoles & Games
My computer is sick. I cant get my icons on the desk top. When on at any time the following comes on the screen" an error has occurred int he script on this page". I also get a message that as...
if anti-virus scan doesn't work, you need to wipe your hard drive and re-load windows. If you don't know how to do this, bring it to your local computer shop.
Jun 03, 2008 | E-Machines Computers & Internet
ViewSonic Optiquest Q19wb LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
