Question about Briggs & Stratton Garden
Blocked muffler muffler broke off.how to remove screw in part left in block?
    Sergeant:
  • 342 Answers
Jimmy you may have to drill it out carefully. Drill in the center and then try and tap a flat head screwdriver into it. Use some WD40 and give it a few mins. Then turn CAREFULLY.
Posted on Jul 20, 2013
2007 ford focus. Idler pulley bolt broke off in engine block. How do I remove the sheared off bolt int eh engine block?
Buy a tool called an "easy out" its like a threaded screw with a fine point on the end of it and the other end has a spanner or socket fitting. You drill through the centre of the broken bolt , insert the easy out and screw the easy out into the hole. The easy out is a left hand thread , so as you are "tightening" the easy out, it is actually undoing the broken bolt. Spray bit of CRC or WD 40 around the broken bolt to assist its removal.
Mar 21, 2017 | 2007 Ford Focus
I broke the rusted muffler off in an old push mower-it screws into the block-I don't have uch to grab to get it out-applied marvel mystery oil-how can I get it out without destroying the engine b
try heating with a torch or maybe wd-40 better than mystery oil on breaking bolts loose let it soak a long time then get a revers drill and dril and easy out it make sure reverse drill a must
Jul 30, 2012 | Briggs & Stratton Garden
How do I keep the muffler screws from coming loose?
buy some lock tite put on the bolt it will stay on
Nov 30, 2017 | Garden
Installed new carb-saw will idle fine,but will not rev.Idle scew has no effect on r.p.m.As soon as you hit the throttle,saw dies.Almost act's like the chain brake is on but it is dissengaged.Both...
There are a few things to check, if the muffler has a spark arrester gauze in the out let this may well be blocked, remove the muffler and the gauze, does the engine now rev? if yes either the park arrester is blocked or the muffler itself is blocked, if this does not cure it, check the flow of fuel from the tank to the new carb, replace the filter in the fuel tank and try again, if this does not help try running the saw with the air filter removed, if it revs normally the filter is blocked.
Aug 28, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
One of the bolts that holds the muffler on broke off flush with the head. how do you remove the broken bolt from the clyinder block?
You need a screw extractor. Google it. There are several styles. They aren't expensive. Basically you drill a hole in the bolt (a little smaller hole than the bolt so you don't ruin the thread in the engine block), then you tap the extractor into the hole and turn it with a wrench. Good luck.
Apr 07, 2011 | Husqvarna Garden
Fuel is leaking from air intake of carby whenever i press trigger to start
If the saw has a spark arrestor in the muffler it could be blocked, or the exhaust port may be blocked, remove the muffler and check/clean, if that is all clear then it has to be the carb needle leaking, you realy need a small bulb pressure tester to check this, put approx 2 psi into the carb fuel inlet nozzel, this should hold steady, if not the carb is leaking, you will then have to remove the carb, take away the screws holding the metering side diaphram cover ( usually chrome plated with four screws, and a breather hole in the middle of it ) remove the diaphram and gasket, the needle will be held in by one screw securing the metering lever and spring, do not lose the spring, replace the rubber tipped needle, re assemble the carb and try again.
Good luck
Feb 04, 2011 | Garden
Starts easily, but won't rev for 10 mintues. After warm, max speed is low / lacks power. New plug & gas filter
Check to see if the muffler is blocked.There is a screen (spark arrester) at muffler exhaust these get blocked. Usually 1 screw holding it in. Remove screen and replace or clean. I use bernzomatic torch to burn out these deposits.
Oct 01, 2010 | Husqvarna Forest & Garden 125bt Backpack...
When you first start the blower on choke then you mover the lever off choke it runs rough and has no power I just tuned it up last month
check carb adjustment screws. Also may have a blocked muffler. There is a spark arrester screen that becomes blocked. Usually 2 screws hold this in place at muffler exhaust, remove screen and use small tourch to burn it clean.
Sep 27, 2010 | Echo 90072 Pb603 Blower Repower Tuneup Kit...
Garden Logo
27 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
