Question about Snapper Garden
Battery I recharge the battery. Put it into mower and the mower runs the battery down and it will not start.
    New Friend:
  • 17 Answers
Has the mower been used regularly? If so, how well did it run?
Posted on Jul 20, 2013
  • 1 more comment
  • Linda Hager Jul 26, 2013
    The mower runs great when it starts. This started happening last summer. I bought a new battery last year. It has sat a year without starting
  • Clint Fonder Jul 26, 2013
    Did the mower sit in the cold. If so, it's probably damaged and needs to be replaced. If the battery is allowed to sit in below freezing temps for an extended length it freezes and it won't hold a charge long. Charge it up, use the mower, then remove the black negative cable. If it doesn't go dead then there's a power draw from the mower. If it goes dead, it's the battery.
  • Linda Hager Aug 09, 2013
    The mower won't start at all. How can I test the battery to see if it is any good?
Needing to know how to keep the riding lawn mower running?
Can you tell us what the model of the engine is that is on that unit?
Aug 19, 2017 | Garden
Black and decker electric mower wont start
Check and see if the battery is actually charged. If the battery sits run down all winter they have a habit of not holding a charge. and needs replacing.
May 22, 2013 | Black and Decker USA Black & Decker 36V...
S2046 low battery tried to start. Replaced battery now no sound, no start. Yes did hook up correct cables. Where can I find images of safety switches?
When trying to start with a low battery the engine Sometimes will stop on the top of the firing stroke putting it under extreme compression..almost like being stuck..you must turn tne engine backward a little just enough to get it off the compresdion stroke then try and start..This very same no click no nothing even when jump start happened to my cub cadet this summer after trying to start with a low battery...i used a pipe wrench and turned the dry shaft back and it started..then and all summer...give it a try good luck..
Nov 14, 2012 | Briggs & Stratton Starter Scott's Equip...
Battery runs down after about 5 hours and has to be removed and recharged. This leads me to believe that the battery is not being recharged in use. My supplier says nothinhg is wrong and I am stopping and...
Hi, has your supplier actually tested that the mower is charging? If you have a multimeter check the battery voltage with the mower running at about quarter throttle. It should be higher than 12.7 volts, usually somewhere around 14 volts. If it is not the charging system requires checking. Hope this helps, regards Phil.
May 19, 2011 | Garden
Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Jun 24, 2009 | Garden
Installing lawn mower battery
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Sep 09, 2008 | Garden
Garden Logo
62 people viewed this question
Top Snapper Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
mburke3
Are you a Snapper Garden Expert? Answer questions, earn points and help others
