Question about Samsung HDTV Digital Terrestrial Receiver
Terrestrial DV3T HDMI
How do I record on the Terrestrial DV3T HDMI
I need tv code for UMC DV3T
Check these codes:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Mar 23, 2012 | Televison & Video
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
TV OK when displaying Sky, but on terrestrial the picture occasionally breaks up with audio crack. Aerial signal is good, with a new aerial and aerial amplifier. Problem is gradually becoming more...
Sounds like a simple cable issue, have you tried switching out the audio source cable? Or are you running HDMI? if so I would switch out the HDMI cable also.. Hope this helps..
May 28, 2011 | Pioneer PDP-4350HD 43 in. Plasma...
I can't get my back speakers on when I'm watching TV in HDMI. I have a new TX-SR608
What is feeding the video/audio signals to your Onkyo receiver? Are you getting your input from a satellite receiver or cable set top box? Or are you just using you TV with a coax feed from a terrestrial aerial?
You need a receiver that will decode Dolby 5.1 or 7.1 if you want to use surround sound. If you are using your TV as the reveiver and it has that capability then the problem is probably the type of HDMI cable you are using. You need a cable that has 'audio return' - in other words it will feed the digital audio (from your TV receiver) to the Onkyo box. Some HDMI cables do not include 'audio return'.
Check what type of HDMI cable you have.
If you respond with answers to these questions I will be glad to provide more assistance.
Feb 16, 2011 | Onkyo Audio Players & Recorders
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
Recording from sky+ box
try hooking up a splitter to the coaxcil cable ;run one line of each output; one line goes to your main box the other to your dvd recorder ;hook up to your tv how you want.switch box helps.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Ive just moved to a house with sky all ready and have not got a clue how to set the thing up. I have a 50in PS-50Q96HD Samsung HDTV Plasma. I have the sky cable and the normal tv cable, what goes were...
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
summary:
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
Hope this has answered your questions
Cheers
Little Dish Fitter
Feb 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
New hdtv
First off, scart has an auto detect feature across pin 8, HDMI does not. If you have turn your TV to the HDMI channel, and at some point turn off the HD source device you are going to get a blank screen, you have to manually turn your TV back.
In regard to whilst you are recording it sounds like you may have tuned in channels on your DVD but not your TV.
Do you have an RF aerial lead connected from the DVD output to the RF on you telly?
Do you have a sky/cable box connected to your TV via scart?
Does the DVD have DVB (digital video broadcast) if so and you have none of the above that is the problem, any tuner running off a single RF lead can only record/play 1 channel at a time. If you have no RF lead going to the TV, then the TV cannot show any terrestrial channels.
Jun 15, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Samsung HDTV Digital Terrestrial Receiver Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
