Question about Acer AL2216W LCD Monitor
Power cannot find power input on monitor, no power when plugged into desktop
    Master:
  • 663 Answers
There are monitors which have their own power outlet and there are some which don't have any.
If you are sure that the monitor doesn't have power outlet, then make sure that you press on the power button.
Please send me the model name of your monitor so that I can take a look at it and tell you what to do next.
David
Posted on Jul 21, 2013
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
Have a Pavilion Desktop HP with upgrade from vista to windows 7 ultimate. Turned the power on and no blue light and no monitor yet the fans were running. Computer monitor said no input and went back to...
Power supplies tend to be either working or not working. I would start with the computers memory, reseating the memory cards (there are plenty of tutorials on the web for how to do this). If the power supply fan was running, chances are you did not need to buy a new one. Does it do the same thing with the new power supply?
Apr 15, 2011 | HP Pavilion Elite M9060N PC Desktop
I have a flatron w2253tq and have "analoge power saving "on. I cannot see the desktop
Is the monitor connected to the computer using a VGA plug (a smaller one, with 15 pins in 3 rows), or a DVI plug (wider one, with flat pins in 2 rows)?
From what you write, your monitor is switched to the analog input (VGA). It doesn't sense any signal on that input and hence goes to power down mode.
You need to go to your monitor's on-screen menu and select the digital input - you should see the picture then.
Jul 02, 2010 | LG 22" FLATRON LCD Monitor
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Sinecerly
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
Computers has power but will not turn on monitor,fans on blue light on, yellow light constant. cd slide opens and closes normal.
First the obvious, monitor is on? Cables are connected securely to back of monitor and PC? Power cable/power adapter are all connected and plugged in? If a power adapter is used, it will feel warm.
I am assuming it was working on some point and then stopped.
If you are getting power to monitor and it's power light is on, then I'd suggest a problem with the video output on PC
If you are not getting power to monitor or it's light is not on, the problem is with the monitor.It may have gone out on you. Try attaching to another computer.
Oct 05, 2009 | E-Machines T6528 PC Desktop
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
No input signal after downloading camara photos
check the num lock after power on the machine if it is working it is the problem with monitor otherwise it is the problem with system.
May 17, 2009 | E-Machines eMachines Desktop PC
Acer AL2216W LCD Monitor Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
