Question about Pool & Spa
I have a pentair pool pump, we have pop ups that push the dirt to tbe bottom of pool and then the suction at the bottom is supposed to.suck the.dirt out. but its not working. we replaced. the.orings and made sure they r all lubricated but doesnt seem to be fixing the problem. water is.just dirty/cloudy blue.
    Problem Solver:
  • 21 Answers
Do you have water flow? Tested the water? Do you have pics of pump, pool, filter?
Posted on Jul 28, 2013
Pentair 1 1/2 hp pool pump works while skimming but loses prime when vaccum gets plugged in
the pump is doing what it was designed for any difference in suction will make it error out you might have to set it on manual to vacuum
May 11, 2014 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Kreepy Krauly has very little suction thru head but plenty thru hose
most all pool cleaners generate there motion with a thing called a venturi ! thats inside it usually moves a small propeller from the action of water being sucked hard thru the hose , on most the path to this "propeller" is different than that of pool debris , i suspect this alt path is part ways blocked , a simple way to clear is to connect garden hose to suction port of cleaner and force water Back in other direction other than that sometimes dissasembly is need to lube and clean hidden ports inside
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Tail on pool sweep is not moving
screw on bottom open up it will let water in and tail will wag
Jan 27, 2013 | Pentair White/Gray Legend Platinum...
My new Optiflow pump surges..............it seems to not be pulling the water thru the sand filter and discharging as it should. Sand filter gauge fluxuates between 0 and 3 lbs of pressure.
it sounds like you may have a suction side leak on the pump. check the lid o-ring and the suction side fittings to see if there may be a possibility of air being sucked into the pump and causing it to act like it's picking up prime and then losing it.
Jul 25, 2011 | Pentair OptiFlo Aboveground Pool Pump 1 HP...
Pentair Legend with boster pump dosent stay on bottom of pool. Seems to float near top of pool more than it does staying on bottom when its suppose to be cleaning.
Make sure that your wheel RPM is not greater than 32. If the RPM is too high, the cleaner will be forced from the bottom of the pool. Make sure that your back up valve is cycling properly because it, too, can cause the cleaner to lose contact with the floor. You might need to use a diverter to make sure that the pool cleaners not getting too much pressure.
Feb 28, 2011 | Pentair White/Gray Legend Platinum...
Pentair pool pump strainer basket has a lot of air bubbles never seem to fill up .
either you have a suction side air leak or the pump is too large for the plumbing and is cavitating.
Jul 10, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Where dothe hoses go
Suction from the pool goes into the front of the pump housing ... Discharge from the pump goes to the filter. If multi-port, there is a suction and a discharge port identified. If it is push/pull, Top port goes to waste, center is water in, bottom is water return to the pool.
Pool water is suppose to go into the top of the filter and out the bottom for return to the pool.
When manipulating the valfe (multi-port or push pull), ASSURE the pump is OFF! If multi-port valve, only turn the handle clock-wise.
May 16, 2010 | Hayward Sand Filter System & Tank 21" 1...
Pentair Great White pool cleaner not walking
Make sure that your automatic pool cleaner is getting the proper pressure from the return lines to move the wheels. Also, make sure that the filter bag is clean and the the impellers are free. Both of these can restrict movements. You might also want to check your hose and make sure that there are not blockages/knots/etc.
Apr 19, 2010 | Pentair White/Gray Legend Platinum...
I have a Shasta pool from 1996. I replaced the
either you have an air leak somewhere on the suction side or your impeller is very clogged. you can fill the pump with water and turn it on, it should try to pick up prime, right when it starts to pull in some water turn it off and try to listen for air leaks or water squirting out somewhere on the suction side. Also, remove the pump basket and try to feel the impeller to see it there is any debris in it. the main cause for a clogged impeller is a cracked or broken pump basket. Also, if the pump has run dry for any period of time, the threaded fitting on the suction side of the pump can shrink and cause a large enough air leak to keep the pump from priming.
Nov 14, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Pump is not pulling the water from the pool
*Check all of the drain plugs*...You would want to check for air leaks on the suction side of the pump. Make sure that there is water at least 3/4 of the way up in the pump and the valves are in the right position (sometimes turning the skimmer off and just sucking from the main drain can help). Also check to make sure that there is water in the skimmer, and it is not getting sucked dry. Next lubricate the pump lid gasket, and try some silicone around the threaded pipe on the front of the pump. If all this fails you could have some debris stuck in the impeller.
Apr 05, 2009 | Pentair Superflo 2 HP In Ground Pool Pump
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
