2002 ford taurus overheats. Just replaced radiator, waterpump, thermostat and heater core. what else can i do to repair. also, ford flushed the system.
About the only thing that you didn't list is the cooling fan. Are you sure that it's working properly? Drive the car until the engine starts to get hot. After awhile you should hear the cooling fan come on. After you have driven the car for a while, park it and open up the hood. If the upper radiator hose is almost too hot to touch, then check to see if the coolant fan is running. If it isn't, then turn the AC switch to "AC MAX". If the fan still doesn't come on, then a malfunction is indicated. Try to locate the fan control relay and swap it with another relay that has the same part number. Use a relay that will allow the engine to run. Allow the engine to reach operating temperature and see if the fan comes on after switching the AC switch to "AC MAX". If the fan now operates, then replace the relay. I hope this is helpful to you. Thank you for trying Fixya.com. If this does not solve your problem, then post a comment and I will respond by getting into more advanced diagnostics.
