Question about Sony VAIO VGN-NR385E Laptop
Bios reset vgn - Sony VAIO VGN-NR385E Laptop
I want break our vaio vgn-sz440 bios password.i forget it
BIOS password can only reset by changing Jumper settings on the Motherboard. For this you need to open your notebook. You have to be very cautious while doing this, if you are not comfortable doing this, take your notebook to a nearest Computer repair shop. You can refer videos on Youtube to achieve this as there is no other way aroud to reset BIOS password.
Let me know you need further assistance on this. Thanks
Jun 23, 2011 | Sony VAIO VGN-SZ440 Notebook
Please advise how to reset the biose on vgn-s28gp,i try to find reset jumper but i did not find out please help. aqeel.
Not sure which key Sony used but the easiest way to reset the Bios for a laptop is to start teh computer and go straight to Bios and select to restore Default settings. All Bios setups ahve this option. It is normally the F2, Del, F10 or F12 key right after you see the initial splash screen after tuning the computer on. The only other option I can think of without tearing the system open would be to remove the power cord, the main battery and the Bios battery if you have access then put it all back. In some models you can remove teh covers from the hard drive or Ram on the bottom of the computer and get to the Bios battery to remove it. I know a lot of HP models have that so it may be an option with the Vaio.
Jun 16, 2011 | Sony Vaio Vgn-s28gp / Vgn-s380 / Vgn-s380b...
Sony vgn-bx540b bios master password
If you are not the one who set up the Bios password, your options are to keep guessing or reset the cmos.
To reset the cmos, open your laptop and look for a small, silver, circular battery. Make sure everything is unplugged and remove the battery. Then, simply place the battery back into the computer. This should reset the bios and allow you to access it.
Hope this helps!
Jun 14, 2011 | Sony VAIO VGN-BX540B Notebook
Need SONY VAIO VGN-FJ170B BIOS password reset method...Please help.
To reset the BIOS password on your Sony VAIO laptop read the information from this link.
Apr 18, 2011 | Sony VAIO VGN-FJ170B Notebook
I cant remember the bios password of my notebook model sony vaio vgn-a497xp
You can reset the BIOS password. To reset the BIOS password read the information from this link.
Feb 24, 2011 | Sony VAIO VGN-A497XP PC Notebook
I'm forget my sony vaio vgn-tx670p bios password??
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Jan 06, 2011 | Sony VAIO VGN-TX670P/B Notebook
Need one time bios password for sony vaio laptop, electrical storm jacked up the operating system lost bios password, need to run diagnostics model numbe vgn nr140e can you help
in order to reset the bios password you will need to remove the cmos battery and leave it out for about 15 minutes. This allows the stored up charge in the capacitors to dissapate, and after they discharge is should be reset back to original factory bios setting.
once into your bios, make any changes needed for specific hardware before you reboot computer and go into diagnostic testing mode.
Dec 17, 2010 | Sony VGN-NR140E/S Notebook
Sony ,VGN-AR605E onetime password
Remove the CMOS battery and replace it after 5 minutes. It will reset your bios to default configuration. :)e421fa4.jpg
thanks to electronic clinic for the image
Mar 09, 2010 | Computers & Internet
I forget Bios password in my vgn-ux280p how to reset it
http://www.docs.sony.com/release/VGNUX280P.pdf
On page 146 of the manual it says you have to take it to a service center, this tells me the device needs to be opened to trip the bios battery. If BIOS reset is not part of your warranty then you will need to either pay a service center or open the device yourself remove the BIOS battery, turn the computer on then off and replace the BIOS battery. The BIOS will be reset to default and your BIOS password cleared. REMEMBER opening the device WILL VOID WARRENTY!!!
Jun 23, 2009 | Sony VAIO VGN-UX280P Notebook
Sony VAIO VGN-NR385E Laptop Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
