Question about Microwave Ovens
Sanding speed setting
Optimum speed setting for pre paint spot sanding on wood.
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Read your owner manual. download for free
www.retrevo.com
God bless you
Posted on Jul 20, 2013
Microwave rusted inside
First thing you can do is fix it by sanding it and feather edging the chipped paint and then prime it and let it sit for maybe 4 hours and lightly sand it with really fine wet 320 grit sand paper or finer. You should use paint that is gloss and heat resistant like you can use melamine.
Or just buy another one.
Mar 22, 2016 | Russell Hobbs Microwave Ovens
What coating is used in oven? Need to replace some as is peeling.
Appliance touch-up paint will work well. Recommend some LIGHT sanding before painting to assure a good bond. VERY important that the paint is completely dry - at least a day or two, with the oven door open - before you use the oven.
Mar 12, 2016 | Oster Microwave Ovens
Why is the inside panel of my microwave rusting
There is a significant amount of steam given off during cooking. If your fan is not working or your vents are blocked, the moisture stays inside and hence; rust. You could repaint by doing a bit of sanding and using a tremclad rust paint.
Dec 13, 2014 | Kenmore Elite 79203 Microwave Oven
When I use my microwave, it seems it was spark happening when I use it. I'm afraid to test it again. Please tell me how I should know it's safe to use
2 things cause sparks.... a damaged Waveguide RF window or bare metal inside the cooking area. If you note bare metal you can sand and paint it with an appliance enamel paint. (no lead paint!) Just make sure to only sand the area your painting as any sanding scuffs not painted will hasten a repeat performance of the sparking routine. The RF will bounce off bare metal and cause the sparking. Once PROPERLY painted it no longer sparks.
If it is coming from the area of the Waveguide RF window... Make sure the window is replaced before next use.
Thanks for choosing FixYa,
Kelly
Apr 21, 2011 | Frigidaire Model PLMVZ169GC Microwave Oven
The enamel is wearing off where the back side meets the base on the inside of the oven. No sparks are flying but is this repairable? Emerson MW8775W Microwave Oven
Small areas inside the cavity can be repaired. The bare spot must be very smooth. You can sand it down if needed and then repaint. There is a m/w cavity paint sold in a spray can, but I've had really good luck using regular appliance touchup paint. Just be sure the spot is very smooth when you finish. Use several thin layers of paint instead of one thick layer and you should be ok.
Dec 28, 2010 | Emerson MW8775W Microwave Oven
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Chipping/peeling rusting paint in interior under carousel
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
May 11, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
White bottom panel inside the microwave is peeling in two spots. What can be done if anything?
affected area would need to be sanded and re-painted with microwave paint. repairclinic.com sells the paint
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My high power GE Advantium microwave is sparking
Your problem is a common one. When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
May 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is rusting inside. mainly the area where the turning wheels meet the base. I have sand and painted with microwave paint but after a few weeks the paint area around the wheels is rusting again.
try the microwave touch-up paint again but this time clean the spots you sanded with rubbing alcohol. also make sure the rollers turn freely
Jan 31, 2009 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
