Question about Gigabyte GA-8KNXP Motherboard
Hdd i can't install any os on my computer? after format hdd sata. later window 7 do you think the IT who program my cpu do this? pls help what it is, i can't format my 8 pcs hdd. tnx
    Brigadier General:
  • Gigabyte Master
  • 3,400 Answers
DID YOU FOMAT THE DRIVE BEFORE TRY INSTALL WINDOWS 7.YOU DON'T HA'D TO WINDOWS TAKE CARE OF IT.GO IN TO BIOS AND SET CD-DVD.FIRST BOOTDEVICE .
LET ME NOW OF THE DEVELOMENT.
Posted on Jul 19, 2013
Testimonial: "the same way sir! i fix my computer almost 9 hours! but my 2 eyeball go up, what i'm going to do? because my friends of my friend is IT who assemble my 8pcs pc. i don't know what's happen when i format only 1pc because some game can't run , that's why i decide to change my os. after that i can't install any 3 kind of os in my cpu . what do you think i'm going to do? if you have any friend who can fix like this problem you tell her? tnx a lot again for comment"
  • Gigabyte Master
  • 3,606 Answers
Hello here is the mainbords homepage:
http://ee.gigabyte.com/products/page/mb/ga-8knxp_1x/download/
You have to open the bios first, and select to boot from the dvd drive.
If any doubt how to do this, download the manual from the home page.
Or watch this video:
http://www.youtube.com/watch?v=Oy2R3Tl9rIE
Good luck
2 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: I cant install vista OS on this MBD , by sata HDD
does your motherboard detect the SATA hardrive???
if the machine can't detect the SATA then all is losted.
go to DOS and enable the hard drive detect, make sure the machine knows there is a SATA harddrive.
Posted on Oct 14, 2008
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
I think my hdd is broken, windows does not recognize it.
I have the same problem. It's too late, I know, Diego, but I found this silly solution that I am posting that might work for others. Plug the Toshiba HDD into another USB Port: (Probably Windows OS retains each stream that it has started, and these streams need to be deleted, in the same sense that some apps won't open the file it has open currently.) I read in another forum that the computers USB ports had been fried after a power surge!
Might work for someone.
Jun 11, 2012 | Toshiba HDD2H92) 500 GB SATA Hard Drive
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
Adding 250gbhd to double my storage.Hdd in bios but not in "my computer"
Is this an internal or external drive? If it is an internal drive, you need to partition and format the drive. For Windows XP and later, this is available in the drive management service. In Windows 7, click Start > Control Panel > System and Security. Look in Administrative Tools and click on Create and Format Hard Disk Partitions. (Make sure that you have logged in as the administrator.) In the lower section of the window, the new hard drive should show (probably as Disk 1). Select the correct drive (it will probably say unallocated space). Click on Action > All Tasks to find the option to format the disc. If this drive will be used with the current computer or only with the recent Windows OS, format the disc in NTFS. Mac's have a similar utility but HFS is their current file system. If the drive will be used on multiple computers with different OS versions, format it in FAT32.
Other programs (Partition Magic, Partition Manager) will give you more options for formatting.
If this is an external drive, looking for the drive in Disk Management will let you check if the OS finds the disc but has a problem with the format.
I hope this helps.
Jun 07, 2012 | Computers & Internet
Windows install doesnt read sata drive but BIOS does
change the hdd's data cable it could be helpful ,,, sometimes when the hdd have a bad sectors it becomes not accessible there a good program to repair bad sectors called ( hdd regenerator ) after you use it ... you'll be able to format your hdd ...
Mar 07, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
How can i install windows 7 on a new sata ******* a msi k8n neo4 motherboard with mainboard cd?
it has nothing to do with the motherboard make sure you format the hdd before you install the OS
Jan 31, 2012 | MSI Computers & Internet
My desktop computer keeps freezing about 3-5 mins into start up with windows 7 ultimate 32 bit. I attempted to install windows 7 pro 64 bit, formatted the hard drive, then started to install and my...
a custom built computer check every connection a computer needs current and data to travel up to and through every device for a computer to work properly
check the cmos battery make sure the seat is cleam this will apply to the ram as well make sure the sockets are clean and they are seated securely
what sort of ide connections are they do you mean molex power connections?
make sure the leads from motherboard to hard drive sata and electrical are securely seated also check all of the connections to drives cd/dvd floppy and usb
hope this helps
Jun 29, 2011 | HP Computers & Internet
I have an Acer Extensa 4620z, i can't load the OS, i've tried with XP and Win7 and there's an error, i tried to change the setings in BIOS, but there's not any option to change anything about the SATA or...
yes quite right.. when u start the install process I'm sure you noticed that it asked you to press F6 to install any 3rd party RAID / Sata drivers.. these can be downloaded from the manufactures web site..
what concerns me is that windows 7 Ultimate has these drivers built in!!! did u try windows 7 ultimate ???? not the OEM version that ships with systems ,, use a full version..
also DO a full format not a quick format.. when win 7 or xp instillation boots,, delete all partitions and do a full format..
if that fails u need to replace the hardrive,, A dead harddrive will give the same error!!!
Sep 14, 2010 | Computers & Internet
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP Motherboard Logo
54 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
