Question about Cub Cadet Garden
Rear end oil
How do I put in oil in the rear end of a Cub Cadet 1045
buffalonyman
  • 1865 Answers
SOURCE: Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Posted on Jun 16, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
dcurryn601
  • 60 Answers
SOURCE: where does belt tensioner spring
go to this site and put your info in and you should find what you need
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
Posted on Jul 26, 2011
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Diagram for drive belt pulleys for cub cadet 1045
Round the two outer pulleys on the deck. Round the the outer pulley in middle deck, round idle pulley inside, next pulley in center of deck to drive pulley
May 03, 2012 | Garden
What are the propper oils and lubes for the model 127 cub cadet?
Well, personally, i use a normal engine oil; what ever your preferance. i use pennzoil. for the engine, the weight that they call for at cub cadet in those days is winter-5w20-summer 10w30. they call for a low ash oil, you can get it at any cub cadet or internation harvestor dealership. the rear end, if its a hydro stat takes hy-tran fluid, also sold at the dealer. you cant use anything else in a hydro, theyre real touchy. if its gear differential, any 80-100w gear oil will work. hopefully this helps, ive been dealing with old cub cadets for a close to 20 or more years. good luck!
Aug 14, 2010 | Cub Cadet Model 18611862 Parts Operators...
Cub cadet hydrostatic transmission new lawn mower, hydro growls pretty bad when taking off, is this normal for the 1045 or 2045 series?
check the hyro oil level is up to the correct mark. but some hydro units make a noise if you set off on full revs quite rapidly
Jun 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
15 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
