Question about Saws
RX5112K manual Just need to know optimum speed setting for a pre paint spot sanding job on wood. Thanks
    Sergeant:
  • 468 Answers
I can't find any information of that saw on the internet. Do you have the correct model no.?
Posted on Jul 22, 2013
Paint will not dry
Could be the paint you're using was old, sat around too long and was not properly stirred, before applying? or did you apply multiple coats without waiting enough or too long in between? You will have to strip all the paint off using a chemical paint stripper. Then wash off all the stripped with the proper solvent, then wash off the solvent. Make sure the wood is totally clean. Then sand lightly to open the pours of the wood. Apply one coat of primer, let dry, then apply as many coats of paint as you want, just make sure its dry between each coat, etc..
Aug 26, 2014 | Tools & Hardware - Others
Tip
How to spot paint repair your car, etc!
Easy job for anyone in 9 simple steps!
1st) You will want to have a few simple tools.(Sanding paper, Auto Paint, Clear Gloss, A paint gun or airbrush, primer, masking tape and/or masking paper,car wax.)
**** [Note: the directions for each of these tools and/or products are clearly marked when you buy them & ech one's uses is different, so please follow directions for each!]
2nd) You will separate that spot from the rest of your car by masking off that area.
3rd) You will sand that area down to the metal.
4th) You will take your sand paper (Medium grit) and scuff up the area.
5th) You will clean all dust from that area by blowing it off and/or washing it off (Simple soap and water will do), then dry it completely.
6th) You will spray primer the area to be fixed. (one or 2 coats will do.) then let it dry.
7th) You will scuff the area up with sandpaper again (medium grit) then lay your basecoat paint down on it (3 to 4 coats) and let it dry between each coat.
8th) You will scuff the area up again with the medium grit sandpaper and you will spray clear gloss over it (3 to 4 coats) and let it dry.
9th) You will wash clean againthe area and buff to more of a showroom glow!!!
Now you are done!
You can apply these basic methods to most any paint jobs, for they are the basic way an pro auto painter does a good paint job....
Thank you for your time!
Have fun!
on Dec 29, 2009 | Acura Legend Cars & Trucks
Fibres appear on canvas after painting
it is pretty obvious that you did not prepared canvas correctly, before you use your medium you need to prepare it. use gesso to even the surface of the canvas seem like you are using water based paint on natural fibers.
fibres in the canvas are picking out the water, swell and raise from the surface,
easiest way to fix this problem is to stretch well your canvas, then use flat knife or broad spatula and evenly work gesso into the working surface, wait day or two and repeat the exercise, sometime even more than twice, if you are doing showpiece which will be covered with high gloss finish, apply at least three to four layers of gesso sanding with 600grit block between layers, your artpiece will then really shine.
if you work on paper, use good quality aquarell (watercolour) or similar paper, stretch it well, pre-wash and they use your airbrush tints or paints. gesso or fixative can be used as well on paper.
if you paint on wood, you definitely need two layers of gesso, if this is very light wood - probably even more, oak and dense woods, especially well seasoned (i tend to buy wood from demolition sites and then make my own as i need) are best for the purpose, do not use planks thinner than 10mm (3/8"), my preferred is actually 20mm (3/4").
if you have any other question - feel free to ask, do not forget to rate... :-)
Jan 30, 2014 | Airbrush-Depot Master Airbrush Model G23...
Finished paint on solid-wood doors
sand smooth and spray on everything. Use a low pressure spray unit. Anything else will leave marks . Remember the finish is only as good as the start so brush in a primer and then sand out brush marks then spray the undercoat and finish coats
Dec 05, 2013 | Cars & Trucks
Sanding speed setting
read your owner manual. download for free
www.retrevo.com
God bless you
Jul 19, 2013 | Microwave Ovens
My Hobart Mixer is chipping and needs paint, what kind of paint?
you can get spraycans of paint from hobartcorp. by the way no paint is food grade
Oct 02, 2009 | Hobart Food Mixers
1994 acura integra--Paint job.
Surface rust can be worse than it appears so then in that case, the bad spots will have to be cut out and new metal welded in its place. (Look at the rust from underside of the panel--moisture gets there and rusts from the inside out) Paint chips can be sanded down. As far as a quote, here in southeast Missouri ...it would be $1600-$1700 for a full body paint job.
Mar 28, 2009 | 1994 Acura Integra
Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
Cab corner extended cab 99 silverado LH
gut what ever coroded you cant do a good job unless the rear box off the box is the real job good luck hope it help fixya our post thanks pierre
Jul 13, 2008 | 1999 Chevrolet Silverado 1500
Saws Logo
26 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
