Question about Garden
Need instructions or video of repairing rear axle on Craftsman mower Model 917252551.
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 68 Answers
SOURCE: I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Posted on Apr 26, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
I was removing the left rear wheel and the axel came off with the wheel. now what do i do?
The axle should have a C-cilp on the end of axle. You need to tear the transaxle apart.
Aug 17, 2013 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a Craftsman lawn tractor and am getting oil leaking around my rear wheels. How major is this problem and how do I fix it?
you need to remove and split the rear axle and thats if you can get the rear tires off from the axle
Aug 03, 2012 | Craftsman Garden
How to fix a broken axle on a craftsman 917.275030 tractor
the axle is held in with a clip inside the trans axle so to do that take the trans axle out of the machine and unbolt the housing
Jun 20, 2012 | Craftsman Garden
I have a craftsman riding lawn mower model #917271080 42 inch cut. When the mower is moving, the right rear axle keeps trying to come off. How can I fix it?
If it is the axle and not the wheel, you will have to take the transaxle off and take the top off to inspect. Likely there is a clip that has slipped or failed.
On youtube you can find videos about how to crack it open and inspect them.
I hope this helps.
Aug 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2007 craftsman dys 4500 model # 917276905 rear axle seal leaking, need to repair and add hydraulic fluid
Call your local sears company parts house they will fix you up.
Best of it
Oct 16, 2010 | Craftsman Garden
Removing the rear tire to repair a flat. i don't know how to get the plastic cover off the axle shaft to get to the axle nut
Pull off the rubber cap. Make a tool by bending a piece of wire or preferably metal and pull the cap towards you until it slides off.
Sep 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Getting Rear Wheel Off A Sraes Craftsman Riding
pull off plastic axle cover in the center of the wheel, remove large e-clip seen on the end with small screwdriver and large washer. take care not to let it fly off somewhere. lift tractor with a jack, pull off wheel then note the location of the square shear pin and save it for reverse assembly
Apr 16, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
