Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
The red standby light flashes in the code of 4 times then pauses then 4 times then pauses.
I have a Sony BRAVIA KDL55HX820 55" 3D LED Flat Panel HDTV and the issue that I've been having is that it turns on then about 5 seconds later its turns right back off. The red standby light flashes in the code of 4 times then pauses then 4 times then pauses... Do you know what that may be?
    Top Expert:
  • Sony Master
  • 75,311 Answers
Over voltage protection function is turned ON. Just unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so and check. If it do not help you, the main power regulator board should be checked and replaced. If you wish to get more details about blinking codes to Sony brand TVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Posted on Jul 20, 2013
mistersony
  • 320 Answers
SOURCE: Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Posted on Nov 11, 2008
  • 1039 Answers
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Posted on Apr 25, 2009
SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Posted on Sep 14, 2009
  • 608 Answers
SOURCE: Hi I have a Sony Bravia KLV-40S200A which wont
I had a similar problem with my 42 Inch Philips 42PLF5432D/37 LCD HD TV. It would turn on but then shut back off after about 10 seconds. Then it wouldn't turn on at all. The problem was a bad capacitor. Several bad capacitors. They are inexpensive and fairly easy to replace if you don't mind digging around in the back of your set and soldering some new ones on your Power Supply Board. Or take the less inexpensive route and look for a whole new Power Supply Board. Good luck. Hope this helps.
Posted on Dec 08, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Posted on Dec 29, 2010
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia showing 4 red blinks any idea what this means, fault?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 27, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Five times blinks to Sony Bravia is related with an IRK error. It is related to its main digital board. In most cases, the main board might need replacement. It will be best to contact the authorized service center for Sony. If you're sound in electronics, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
333 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
