I have an Emerson 20" LCD EWL20S5. I am trying to
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Contact the authorized dealer for Emerson.
Posted on Jul 20, 2013
  • barry ford Jul 21, 2013
    Thx Sasi. Emerson asked me to check back in about 10 days or they shoot me an email when tilt stands come. Also found one on ebay. Thx again
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
SOURCE: Emerson EWL20S5 20 in.
El TV no enciende y desconecte la señal Protect 1, enciende pero la parte inferior de la pantalla no presenta información nitido o es muy poca la información. La power supply esta bien, solo el voltaje panel -6 esta bajo, alrededor de 3,5 v. el audio esta bien¿que puede ser?.
Posted on Aug 28, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
Pairig tv EWL20S5 C
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 01, 2016 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
What size screws do I u for Emerson #LF320Em4A to mount to stand
Contact the authorized dealer for more details. They can provide you the exact screw size details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations. It too will have these details.
Dec 05, 2014 | Emerson Televison & Video
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
Is emerson ewl20s5 tv digital or do I need a converter box?
The set can recieve analogue transmissions or cable signal only, for digital transmission a converter box would be needed
Mar 05, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Can you wall mount an emerson EWL 3706
This web site advertises one they claim will work for this unit, or any 37" to 63":
http://amazon.skakawack.com/Black-Tilt-Wall-Mount-Bracket-for/M/B0019D8OHS.htm?traffic_src=froogle&utm_medium=organic&utm_source=froogle
This was the most inexpensive mount, but there are more if you google "Emerson EWL3706 wall mount".
Oct 21, 2010 | Emerson EWL3706 37 in. LCD Television
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Back panel black circular control button
that connection is the "S - VIDEO" connection which will over ride the yellow video input if used
this can be seen here http://www.emersonaudiovideo.com/pdf/om/EWL20S5.pdf
page 2 of 8 , and zoom in
Mar 27, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Is the emerson ewl20s5 digitally compatible
I looked up the specs for your TV. It says nothing about a digital tuner at all. I believe you must get a box from your cable provider. I'm sure that they want to keep you around, so they should give you a cable box for free.
Jan 29, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Need a replacement stand for Emerson TV model EWL20S5B
I have the stand I never used. what are you willing to pay? im located in ny 11967 so you can figue the shipping in your price .larryb1963@aol.com
Oct 04, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson 20" lcd
bad power board or bad capacitors on the power board service required
May 27, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
