Question about Garden
2000 series 2166 has volts will not turn over or try to start
I was mowing stoped for a minute went to restart it and will not do anything, has juice, gas, oil
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Are there any safety switches on this mower? Like if the blades are engaged it wont start. something like that.
Posted on Jul 21, 2013
buffalonyman
  • 1865 Answers
SOURCE: choke stuck
You may have to replace the choke cable assembly. Sometimes they rust to outer sleeve
Posted on Jul 03, 2009
  • 548 Answers
SOURCE: cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Posted on Aug 21, 2009
SOURCE: I have a Craftsman 675 series rear bag mower that
ours is doing the same thing!!!!
Posted on Jun 27, 2010
  • 100 Answers
SOURCE: We have a 2166 Cub Cadet. After mowing the lawn
Could be couple of things...blockage in fuel filter....tank cap has blocked bleed hole pressurising fuel tank....magneto either coil or condensor on way out
Posted on Aug 13, 2010
  • 7 Answers
SOURCE: Type your problem for a solution...mowing for 10 minintes stoped to ceck blades started mower blue smokeout exhust. stoped mower checked oil will not start checked plug ,filter carbie and control le
to check blade you tilted the mower and got oil where it should not be.
exhaust will clear out, check all controls to see if the spark is still there, allso a compression test check out a lot of problems. if it is low ,under 60 ,
just check the basic the three things needed to run- compression,spark,and fuel. always check things with the spark plug wire pulled of the spark plug. good luck
Posted on Jan 03, 2012
check battery dead if not by pass the brake lever safty switch should start when by pass safty swich bad if not go to starter relay see if it is cliking if not bad if is look for fuse next to lower motor for starter see if blown has to be one of theses
Jul 19, 2013 | Garden
Troybilt riding mower 700 series
try and turn it by hand did the motor seize from no oil?
Aug 15, 2012 | Garden
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
I have a series model 1018 cub cadet with electric mower deck. After mowing for about 45 minutes, I turned off the tractor for a few minutes. When I tried to restart, the battery was dead. I jumped started...
If you have access to an electric voltmeter, with it running check voltage at the battery. The engine should charge the battery and maintain system voltage so that the electic PTO will function. The electic PTO will not pull in if system voltage is too low.
Jul 08, 2011 | Cub Cadet Garden
My 1996 Ducati 900 SS died while riding and there was no electrical power when i went to restart. i just replaced the battery 2 weeks ago. after about an hour of sitting there was enough juice to turn...
Put some charge in the battery and start the engine.
Check the battery voltage exceeds 13.6 volts with the engine speed of about 1000RPM. If not check the regulator and altenator.
Apr 20, 2011 | 1998 Ducati 900 SS
We have a 2166 Cub Cadet. After mowing the lawn around 30 minutes or so it starts to hesitate (like it wants to die out) and eventually it does.Can anyone tell me what is causing this problem. Thanks!
Aug 13, 2010 | Cub Cadet Garden
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Jul 10, 2010 | Cub Cadet Garden
I have a Cub Cadet that wont start.
Easy check is your cable connections and condition. Next would be to remove the starter and test it. Then check the solenoid.
Apr 27, 2010 | Garden
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
