Question about Lenovo Computers & Internet
Hdmi driver my hdmi port is not being recognized, is there a way to download the correct driver
2 Suggested Answers
  • 76 Answers
SOURCE: TV won't recognize PC through HDMI port anymore
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Posted on Mar 26, 2014
My lg plasma Tv hdmi ports will not work?
Have you tried different HDMI cables?
Have you tried switching the ends around?
Are you sure you changed your TV inputs to the correct one?
Not all LG TV's will sense an HDMI connection and offer to switch to the new input.
I know it sounds ridiculous but I had an HDMI Cable break just sitting there. Also they now have HDMI Cable that are Unidirectional, you can plug them in backwards.
Dec 23, 2016 | LG Televison & Video
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
Why doesn't my Emerson lf501em4f not recognize cable box HDMI?
Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
Sep 28, 2014 | Emerson Televison & Video
I have plugged my laptop to my T.V. with the DX-AV08A cable How do I make the laptop go to the T.V. now?
Try rebooting your computer while the cable is plugged in and the television is on. If the T.V. is plug and play, this should get your computer to recognize the T.V. and install the necessary driver. Be sure you have internet connection so it can download the driver if needed
Jul 09, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Mar 26, 2014 | Televison & Video
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Jan 05, 2014 | Televison & Video
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
M4a88T HDMI port does not work
Is the TV turned on and set to the input that you have the HDMI cable connected to?
Have you tried other HDMI ports on the TV?
Have you tried it with another HDMI cable?
Have you tried it with another TV?
Dec 22, 2012 | ASUS M4A88TM LE AM3 AMD 880G HDMI Micro...
HDMI for laptop Compaq no sound
Hello ahmselem,
There are a couple of things to try.
  1. Open up your sound display on your laptop, and make sure that the computer recognizes the HDMI port out. If your laptop came with the port, then your computer would recognize that the port is there only if you have the correct drivers installed on the laptop. You can check that in your control panel/system/hardware devices. Look for Ports and make sure that their is no triangle with an ! in it.
  2. If your computer is set correctly, then you need to make sure that your TV is set correctly. Sometimes (I'm not a TV Expert) the TV need to be configured to each port. Especially if your using a receiver. So if your TV is on the correct input channel, look at the TV's options for audio, and make sure it recongnizes that port as HDMI.
  3. To test to see if the HDMI cable is bad, take a single multi audio plug and place it into the Headset plug on the laptop, and put the other side, which should be either a red and white plug, or compoment audio plugs, and plug those into another port completely, and switch the TV over to that port, to see if you here sound.
  4. If all those fail, then test the outbound port on the laptop, by pluging the HDMI into your DVD player (if you have one) and it will pass the sound through to the TV.
  5. Without knowing your TV, and coupled with my TV lack of knowledge, I'd also suggest reading through the TV manual throughly to see if it's not some simple switch that needs to be flipped.
Good Luck
Mark
Apr 04, 2009 | Compaq Computers & Internet
Computers & Internet Logo
15 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
