My android note model n9000 everything works good but when I make a call my screen go blank and it blinks on in off so I have to take out the battery every time to hang up the call
  • Liz Holder Aug 07, 2013
    i have the same problem. What is the cause and what is the solution?
4 Suggested Answers
  • 1212 Answers
SOURCE: i've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Posted on Apr 07, 2012
nickmar19
  • 7 Answers
SOURCE: MIDI Epad hangs up at the word android will not boot all the way up
contact the manufacture or costumer service for that product and ask for service
Posted on Sep 06, 2012
  • 170 Answers
SOURCE: invalid IMEI number for a galaxy note 3 GT-N9000
Dear David,
please go to xda forum and you can find the solution.and you can recover the IMEI.
it is best place to solve the android problem.
regards,
nuwan.
Posted on Jan 14, 2014
Why is (screen) blank?
What kind of phone is it, Android or Apple?
If it is Android based, try pulling the battery out (if possible), then starting the phone in RECOVERY mode. If you answer with your phone make and model, I can walk you through it.
Feb 22, 2016 | Cell Phones
Problems with incoming calls m-horse n9000
The stock firmware is a beta of the galazy note 2 - and it\'s got some bugs in it. You\'ll need root access, which isn\'t that hard on these phones - check out xda developers forum. Then install malware bytes and Avast and remove the malware and trojans from it. Next disable the small window - as this is what stops you from answering the call - as the windows won\'t disable. After that you should be right to go. Sadly, the final release of the galaxy note has a great feature - answer by button - which the n9000 firmware does not have.
Apr 04, 2014 | Star 5.0 Dual Sim Gps Android 4.0...
My android tablet will not start it flashes the battery but will not start
is it a pipo m8 model ? not getting a listing for this model, if you have it on charge does it still do the same thing, blank screen could be the sd card inside has fell out. this is on some models has an 8gb - 32gb sd card inside. other models it can be a read error of may ram. if it has volume controls on the side hold down the power and volume down at same time and then lift fingers off and see if the android software comes up, can take a few times to get it up takes a bit of practice to get it up but does not work on some. when the menu comes up you will have a list of things you can do choose the one you want to do reset system last know good etc and see if that fixes it. failing that you will need to open the tablet up and remove the battery and check the sd card if it has one inside.
Apr 03, 2014 | Tablets & eReaders
Invalid IMEI number for a galaxy note 3 GT-N9000
Dear David,
regards,
nuwan.
Jan 14, 2014 | Computers & Internet
Download software mobile phone nokia n9000
Access the 'www.nokia.com' web-site to download the software for your model of Nokia equipment.
However, if the "touch" functions do not work, the cell-phone is broken. Take it to the company that you are paying for your cell-phone service, and they will replace it.
Sep 18, 2013 | Microsoft Computers & Internet
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Apr 06, 2012 | Music
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
Feb 18, 2011 | HP Compaq 6735s Notebook
Nokia 9300i displays NOKIA on the inside but blank screen after t
I have the same problem! I stripped mine down - quite easy with a small star driver, but take care - and cleaned the ribbon cable connectors with alcohol. I cleaned everything else that I could for good measure. It worked for quite a while, then just stopped again. I noted the backup battery is dead - I wonder if this has anything to do with it?
Jun 27, 2009 | Nokia 9300i Cellular Phone
Blank screen. Remains blank
Power down, remove the battery, remove the power plug. Hold down the power button for at least 30 seconds. Remove and reinstall the memory module(s). Re install the power plug and try to power back up and see if it works. If it does, reinstall the battery ad you're done. If not, get back to me for some more ideas and further diagnosis.
Thanks and have a good day!
Ron
Dec 15, 2008 | HP Hewlett Packard Pavilion dv6355US PC...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
