Question about Cooktops
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
    Sergeant:
  • 213 Answers
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Posted on Aug 05, 2013
SOURCE: Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Posted on Jan 06, 2008
Eddie Rentas
  • 59 Answers
SOURCE: hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
SOURCE: creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
heatman101
  • 43501 Answers
SOURCE: ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
CDA gas hob ignition
try the fuse ..
Dec 27, 2013 | Cooktops
Cooktop short circuits the electrical fuse when plugged in
Try removing parts or connections until the fuse does not blow.
With a gas hob, you are limited to a short in the ignition system.
As the igniter has failed try removing it. This should solve the fuse problem, if it doesn't, look for a short in the wiring.
Jan 09, 2012 | Thermador 46 in. SGSX456 Gas Cooktop
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Duvalli GHG604B gas hob ignition problem. Ignition has stopped working. Everything is clean and dry. Power and fuse is O.K. I suspect the spark generator unit, but how can I test?
If you know the power and fuse is ok, and none of the knobs will turn on spark, the only thing left is the spark module. The switches would never all go out at once.  Good luck
Jan 07, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Creda gas hob now keeps ignighting
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Gas hob ignition
1) try leaving it off for a while to see if the ingition box needs to reset
2)when you turn on the burnner does the ignition start by itself or do you have to "ignite" the burnner yourself?
3) if oyu have to ignite the burnner yourself, try using a bbq lighter to see if the gas has gotten to your range yet.
4) if no gas present, there is ussually a reset in the regulator. it needs to be reset if it gets low on pressure. you need to have the lines connected and then turn on the gas AND then the appliance. if the appliance is turned on before the gas in turned on the rest will pop.
lets us know what happens :)
Jan 30, 2008 | Cooktops
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
248 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
