Question about Craftsman 16 ga. Finish Nailer Kit with Magnesium Body
Cylender seal +craftsman 351.183150
I need cylender seal for a sears craftsman i6 gauge finish nailer Model 351.183150.
2 Suggested Answers
SOURCE: i need a piston stop
same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Posted on Oct 19, 2010
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
I have a craftsman framing gun it needs a trigger assm took it to sears it cost me 30 dollars to ship it to where ever and tell they dont make trigger parts any more do u no where to mind parts
Craftsman nailers are made by many different manufactures so there are parts out there that will interchange. Best way to find good match for parts is to look on ebay for a nailer that looks like yours and look for parts for the matching brand name. If you can post a picture of your nailer or maybe the model number, I can help to ID your nailer and recommend parts. Good holidays
Dec 15, 2010 | Air Tools & Compressors
I have a craftsman 16 gauge finish nailer, model 918441. it is not advancing the nails. not certain how to adjust. cannot find the manual. is the manual available on line?
Assuming that the nails are correct for gun (16g nails measure .055) and feeder is actually applying pressure to nails (feel spring pressure as you close clip), most likely problem is driver is not returning to top of cylinder. This is caused by low pressure to gun, bent driver, lower bumper missing pieces/cracked, worn oring on piston or lack of lubrication. Remove cylinder and examine condition of lower bumper, replace if broken/cracked; check outer cylinder for check valve in place (usually small band or oring covering series of ventholes) ; replace piston oring as needed, make sure driver not bent. Parts available at sears web site. Good luck
Sep 08, 2010 | Craftsman Tools & Hardware - Others
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
Jul 29, 2010 | Craftsman Garden
Craftsman nailer striker is stuck down after firing.
my porter cable nailer does the same thing. what is the problem
Jan 26, 2010 | Air Tools & Compressors
Need a users manual for a craftsman in-line 15 gauge finish nailer model # 181770. I am having trouble finding the finishing nails for this model #. I looked on the craftsman website and it shows 1 1/2 in....
go to www.manualnguide.com i looked and they have the guide there you can download for free. Any nails will work as long as you get 15 gauge nails only thing that matters is whether or not they are straight or angled
Hope this helps
Nov 12, 2009 | Air Tools & Compressors
Need a manual for craftsman 18 ga comb
go to sears.com where all of these manuals are found in downloadable form.
Oct 29, 2009 | Air Tools & Compressors
My Sears Craftsman 18 gauge brad nailer won't nail unless I release the nails from supply, remove the front cover, slide up I think it's called a striker, then replace the cover, re-set the supply and...
Your driver is not returning. Depending on the model that you have there could be a couple of problems. The most likely is that your piston stop is crumbled and some of your seals are worn or damaged. Whether or not you can fix the nailer depends on if the parts are available from Sears Parts Dept. If you would like some more information about fixing your nailer please post which model it is that you are trying to fix and I can see if the parts are available. I will post the information back to you.
Oct 12, 2009 | Tools & Hardware - Others
We have a Bostitch nailer that leak out of the end
there are o rings inside the nail gun, remove the allen head screws and get replacements.
Apr 10, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Craftsman 16 ga. Finish Nailer Kit with Magnesium Body Logo
52 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
