Question about Garden
What is the minimum and maximum cutting height of an MTD Yard Machines Series 601. Turning radius, cutting height, adjustments, specifications overall
Model # 13AN601H729 497818 Just purchased used. Would like to set the cutting height to it's max height. Are there any adjustments that can be made under tractor on life mechanism. Any idea wher I can locate all specs for tractor overall? Not listed in operators manual
  • 62 Answers
SOURCE: MTD TRACTOR FLIPPED UPSIDEDOWN; NOW IT DOESN'T START ???
Does the engine turn at all? If it does, the you probably need to replace your fuel filter, air filter, and spark plug.
On small engines, when they get turned over like that, oil tends to go places it shouldn't. Usually that means that your filters, and carburetor, and from there into your cylinder, fouling your spark plug.
Check those items, and replace any that have traces of oil in/on them.
Posted on Apr 17, 2009
  • 33 Answers
SOURCE: Clutch/Brake Pedal Problem
first off your biggest problem is its built by MTD.they build about 90% of the riding lawn mowers you see in the stores that are 20 horse and under,every thing from a yard machine to a craftsman to a cub cadet. you need to get under it and fallow the linkage from your pedal to your rear transaxle. that link is adjustable if it is not , then the arm it attaches to is .you need to adjust it whichever way takes slack out of the belt, if all the adjustment is out then replace the belt and adjust it accordingly
Posted on May 02, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
How do I Lower my yard machine mower to cut grass shorter?
there should be adjustments on each wheel.
Place the machine on a flat level surface and adjust each wheel so the blades are at the height you want it to be. Make sure all the wheels are all at the same height. Usually, the bottom of the deck lip to the floor equal all around.
May 05, 2014 | Mtd 22" Yard Machine Push Mower
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
What is the math definition for area?
Area - The size of a surface
Specific
Square
Area = Side x Side
Rectangle
Area = Length x Width
Triangle
Area = Base x Height (cut the answer in half and that is your area)
Parallelogram
Circle
Area = Radius x Radius x 3.14
Aug 30, 2011 | Computers & Internet
What is the toe adjustment for a 1998 ford windstar 3.8L
Hello Snsimpson
Here are all the specs for the Windstar.
FRONT ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal -0.25°
Minimum -0.75°
Maximum +0.25°
Split 0.0°±0.5° Caster
Right
Nominal +3.80°
Minimum +3.05°
Maximum +4.55°
Split -0.5°±0.5° Left
Nominal +3.30°
Minimum +2.55°
Maximum +4.05°
Split -0.5°±0.5° Total Toe [1]
Nominal -0.10°
Minimum -0.40°
Maximum +0.20° Clear Vision [2]
Nominal -0.2°
Minimum -2.8°
Maximum 3.2° REAR ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal 0.0°
Minimum -0.3°
Maximum +0.3° Total Toe [1]
Nominal -0.06°
Minimum -0.40°
Maximum +0.28° [1] Positive value specifications for toe-in, negative value specification for toe is toe-out. [2] Negative value specification for clear vision is counterclockwise.
Nov 16, 2010 | 1998 Ford Windstar
Hi - would like to know seat height, weight dry & wet etc for above model. Pls include any other info you feel may be useful. In Australia the Venture is referred to as XVZ13TF. Royal Star Tour deluxe...
2,505 mm (98.6 in)
Overall width 1,010 mm (39.8 in)
995 mm (39.2 in)
Overall height 1,525 mm (60.0 in)
Seat height 740 mm (29.1 in)
Wheelbase 1,715 mm (67.5 in)
Ground clearance 150 mm (5.91 in)
Minimum turning radius 3,500 mm (137.8 in)
Dry weight 357 kg (787 lb)
With oil and a full fuel tank 383 kg (844 lb)
This is all from the service manual for the XVZ13TF
I hope I have given you the info you need.
Nov 01, 2010 | Yamaha Royal Star Tour Deluxe Motorcycles
What do I need to buy or what should I do if my fuel reserve does not work or what is the fuel capacity for a 1991 Yamaha FZR 600?
var gDcsId="dcsmm6y3q0000004zhgx8uuaa_9g7g"; var dom=window.location.hostname.replace(/^www\./,''); window.onload = function() { init(); setThumbnailimages("galleryThumbNails", "galleryImage"); enableMenu("archive"); initLightbox(); }; Technical Specifications 1991-FZR600
Engine Engine type Liquid cooled, 4-stroke, forward inclined parallel 4 cylinder, DOHC 16 valves Displacement 599 cc Bore x stroke 59.0 x 54.8 mm Compression ratio 12.0 : 1 Maximum power 66.8 kW (91 HP) @ 10,500 rpm Maximum torque 65.7 Nm (6.7 kg-m) @ 8,500 rpm Lubrication system Wet sump Fuel System Mikuni BDST32 x4 Clutch type Wet, multiple disc Ignition system Transistor controlled (digital) Starter system Electric Transmission system Constant mesh, 6 speed Primary reduction ratio 1.708 Secundary reduction ratio 3 Final transmission Chain Ratios gearbox 1st 2.846 Ratios gearbox 2nd 1.947 Ratios gearbox 3rd 1.55 Ratios gearbox 4th 1.333 Ratios gearbox 5th 1.192 Ratios gearbox 6th 1.111 Chassis Front suspension system Telescopic fork Front wheel travel 130 mm Rear suspension system Swingarm (Link suspension) Rear wheel travel 115 mm Caster angle 25° Trail 94 mm Front brake Dual discs, ø 298 mm Rear brake Single disc, ø 245 mm Front tyre 110/70V17 V240 Rear tyre 140/60V18 V240 Dimensions Overall length 2,165 mm Overall width 700 mm Overall height 1,155 mm Seat height 785 mm Wheelbase 1,425 mm Minimum ground clearance 135 mm Dry weight 181 kg Fuel tank capacity (reserve) 18 L Engine oil tank capacity 3.1 L
Jun 27, 2009 | 1991 Yamaha FZR 600
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
If the speed seems to be different after changing the belts, it should return to normal after they break in.
The 600 series has a top speed of about 5 - 6 MPH, see:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=79&p_created=1027096447&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=68&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTYsMTYmcF9wcm9kcz0zMDEmcF9jYXRzPTAmcF9wdj0xLjMwMSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXNwZWVkIGNvbnRyb2w*&p_li=&p_topview=1
Apr 24, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
50 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
