Question about Generac Guardian Electrical Supplies
7.5 amp fuse
Model#0094-1 serial#3220969 phase 1 hertz 60 series imp 34+ fuse blows as soon as you turn battery power on to genrator
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Check all the wiring make sure no corrosion or exposed wires other than that try replacing the button module
Posted on Jul 19, 2013
Vp17-3 bunn o matic will not brew no water will come out if i wait about 15-20 mins it will start spitting out some water like 1/4 full! The heating elements are working on all 3 burners
You have 2 water valves on that coffee maker a water inlet and a dispense valve the warmers are only heat plates the element is inside tank Bunn has a great site for manuals it's a free download
Nov 13, 2016 | Electrical Supplies
How do I find out what the value of my Weather King central A/C is worth?
the question you asked is too vague and you have 2 refrigrants listed as well,, what valve
Oct 16, 2014 | Heating & Cooling
Is hertz the same as amps?
No, hertz (Hz) is the name for "cycles per second". Normal AC power (in the USA) is 60 hertz or 60 cycles per second. 1 kiloherz (KHz) = 1000 cycles per second. 1 megahertz (MHz) = 1,000,000 cycles per second. Amps is the measurement of current flowing through a device or circuit. a 100 watt light bulb pulls about 0.9 amps. A toaster or microwave oven pulls about 15 amps.
Sep 11, 2014 | Microwave Ovens
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
Hi i looking for water pump 10hp single phase borehole 150feet under ground 1500gpm submersible please can you rang run on single-phase 240v thanks harry 00353860818018
Don't knw what your problem is but here is a page that gives you the information, normally 3 phase on single phase motor but if you can change the winding settings you might here is the page hope it helps.
http://www.pentairpool.com/pdfs/CSeriesCommercialBronzePumpOM.pdf
Dec 20, 2010 | Pentair 10hp 3ph Single Phase 220440v 60...
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
Electrical Supplies Logo
77 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
