Question about Refrigerators
Bosch exxcel maxx kgv31421gb/02 fridge/freezer not cooling fridge section
SOURCE: Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
Posted on Sep 29, 2008
MNTECH
  • 1543 Answers
SOURCE: LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Posted on Dec 04, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
woodchuck789
  • 4066 Answers
SOURCE: Creda R335NW Fridge/Freezer. The fridge section
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Posted on Jul 03, 2009
Illeagle
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
Bosch exxel fridge freezer should the light go dim when the door is shut and not off completely
the light should go OFF when the door is shut.(that is if ive read your question correctly).
Dec 18, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
There is a buildup of ice behind the lower section of the plastic back panel which eventually prevents the door from closing.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Hi can you tell me what the red explanation mark on my bosch exxcel frost free version fridge means please. mike
it has a problem and its telling you this,,,most likely its to warm inside of it this could be the thermostat playing up
Jul 04, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
Dodgy fridge light
Generally, these doors drop from excessive weight, a warn part or loose fittings. Unload the door and investigate. You may also want to check that the unit is levelled...the box may be warping/sagging...although this is unlikely.
Dec 24, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
