Air was working in this moring now have no air or defrost
    New Friend:
  • 3 Answers
Why is there a red light blinking on the front of my unit
Posted on Jul 19, 2013
I ONLY HAVE A/C AIR coming from the defrost vents
if you are trying to see if the heater and the defroster works, and only the air conditioner works I would check to see if you have a blown heater blower motor. it might be a fuse but could be more.
Jul 01, 2015 | Cars & Trucks
Freezer works but not blowing cold air in the fridge
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Aug 03, 2014 | Refrigerators
Jeep liberty heater/defrost
check the actuator motor or motors on the heater. It is inside on the base of the heater and directs the air where you want.
May 09, 2017 | Cars & Trucks
Freezer is working and slightly over freezing, but fridge is not working
check air flow. if fan not running replace fan if running but lots of frost on back wall then its a defrost problem (when it doesnt defrost ice builds up blocking air flow to refrig side.) try forcing into defrost if it has timer or ck bimetal (bi metal most common) (on ge fan not common but def heater is). post model for more help
Sep 14, 2012 | Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
My freezer keeps melting andre freezing. usually it is ocurring over night. when i get up in am everything is melted and blowing 29 degree air by 1 pm its blowing -11 degree air and refreezing. Response:...
Manually turning the defrost timer will not tell you if the timer is working, it only tells you the switching inside works, The defrost timer has a motor inside that turns it through it's cycles, this would be the part of the defrost timer that stops working.
But since the unit is freezing and thawing, The problem is more likely the defrost thermostat has came loose or is defective.
Jul 20, 2011 | Kenmore 53642 / 53644 Side by Side...
2006 Merc GM, air flow out the defrost only problem.
sounds like a vacuum problem. Check vacuum lines. Maybe hooked up wrong.
Oct 04, 2009 | 2006 Mercury Grand Marquis
HEAT PUMP PROBLEMS
Defrost cycle is to allow frosy or ice to melt down and not restrict the output air. The thermostat is set too low and in high humidity ice forms quickly restricting the air flow. tur up the thermostat and let the room cool gradually.
May 26, 2009 | Heating & Cooling
Defrost blows cold air
Sounds like you have a plenum door that is not opening when you go into defrost mode. You will have to check all your vacuum hoses and switching valves under the dash to see which one is not working. Hope this helps.
Jan 18, 2009 | 1998 Ford F150 Regular Cab
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
