Question about Philips Magnavox 13MT143S 13" TV
Phillips reset tda9570 - Philips Magnavox 13MT143S 13" TV
UNABLE TO REMOVE SCREW ON TRIP RESET KNOB 92 HERITAGE ANY IDEAR HOW TO REMOVE
Hi Anonymous, look inside reset knob with a flash light to locate screw. If it is a phillips head it takes either a # 0 or # 00 tiny phillips head screw driver. If it is a flatblade try an eyeglass one. Hold the reset knob and undo the screw. Good Luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 25, 2014 | Harley Davidson FLSTC Heritage Softail...
Will not play the music
reset it by pressing the reset button (pinhole)using a pin
Dec 31, 2009 | Philips Audio Players & Recorders
Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Trying to reset a PCto factory defaults
There is a neat site:
http://www.user-guides.co.uk/asp/search.asp?keywords=User+Guides+Phillips+MT2400&recor=1
They have everything you need. Look at the Bios jumper ad reset it.
Hope this helps.
Jan 27, 2009 | Computers & Internet
Oxygen sensor light
i had the same problem when i had a new oxgen sensor put in i did find out that it is in the dash behind your speedometer i tried to do it myself but i got the dash off but i couldnt get the rest off so i just left it untill i can get a diagram to show me the rest of the way i hope this helped a little.
Nov 05, 2008 | 1992 Isuzu Trooper
21pt2216/94 phillips 21'' audio problem
your speaker maybe busted or check the amplifier IC
Oct 22, 2008 | Televison & Video
Phillips TV
What is the purpose for resetting the tv?
Aug 08, 2008 | Televison & Video
I dot know how to reset my phillips SA411X
Hi - You can download the manual from the link underlined in blue below:
phillips SA411X
So to reset remove & replace the battery.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 02, 2008 | Audio Players & Recorders
Help me
Go to the Phillips website to find out the button combination to reset your player. I have a Phillips mp3 player, and I have to reset it every once in a while. If that does not work, call Phillips support.
Apr 21, 2008 | Philips GoGear SA178 MP3 Player
Philips Magnavox 13MT143S 13" TV Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
